228H red flakes in fuel
Sounds like the inside coating is breaking loose big time. Suggestion, keep doing the BB shake and add some small nuts, or leave alone. To prevent flakes from clogging the F/A tube, could put a small sock over the tip. I think POR 15 is drastic.
Agree with flaking theory. I had one like this and after my third bb dance i put lye in the tank, let it sit overnight, and it dissolved all the coating.
phredd
You can leave the CV in place. I remove mine and clean them with lye followed by a weak acid.
"Can anyone please instruct me on what to do next?"
Not being one to noodle around a lot, I'd empty out the fuel, take the lantern outside, put the fuel port in the down bottom position, the blast out the inside of the tank with a strong garden hose nozzle for a while, strongly shaking and sloshing the contents a couple of times. Empty the water out and add new fuel, and fire it up.
If you leave the check valve in place:
First clean the tank of all the lye (i flush with lots of water - dry it with compressed air - then rinse with ethanol - then rinse with CF).
Then I then squirt some carb cleaner directly into the check valve, let it sit for 5 min, then pump it through (you can use the the pump without the stem). Then I add about 10 ml ounce of CF and pump that through. And repeat. I do this to clean out both the check valve and the air tube.
Drip some on your wrist, will know very quick.
HercL4D2
Post by HercL4D2 »
Coleman used red, light grey and brown Epoxy paint inside the fuel tanks. This was applied with an electrically charged part and a negative charged paint. Lye to remove the paint?. I have never tried it. After flushing the tank I had best results cleaning out the small flakes using dish soap in the tank and a steady stream of hot water entering the top of the tank with the kitchen sink leaving the fuel filler cap off. BB's were to much of a pain trying to get out. Pressurized water from a garden hose with a pressure tip and dish soap works well also. Denatured Alcohol to rinse the tank out of water and let sit in the sun or a warm place. Paper towels rolled tight and fitted into the fuel port to bottom of tank to wick out the excess. Repaint inside with a mist Epoxy. I made a brass cap that fit over the plastic straw and glued on with tiny drill bits to make a misting nozzle. Trial and error with a misting nozzle and paint warmed in a pot of very warm water.
In a couple founts i was unable to use water to get it all off. A borescope showed patches that resisted water treatment, but would flake off slowly with CF. So i just use lye now.
And HercL4D2
I am in awe of you ability to re-coat tanks.
No. May rust lightly if moisture left in it each season. Some/many things read about here are by accomplished handy men for the rest of is to admire.
The pricker/cleaning lever is only moved up to clear obstructions. Down is normal operating position.
Rhubarb
Title: The Pie Plant
Post by Rhubarb »
http://www.oldtowncoleman.com/manuals/220H.pdf
How to use and enjoy your 228H.
  Image- Andy
Agree with above. The cleaning lever is always supposed to be the down position when running. And it's not supposed to be used to regulate the light output. These things are either all on, or all off.
"I have to run with the cleaning value at half way up position. If I put fully up the mantle stop glowing."
I think the cleaning levers are made of brass and can become twisted if the lever packing becomes too tight. This happened on my dad's 11/55 220E and probably was why he retired it in the early 70s. The lantern is now running good but the lever still has a ~30 degree twist. A cleaning lever that is functioning properly should significantly dim the lantern when it is turned and the pricker fills the generator orifice. Using the cleaning lever is the way to lower the output when desired of the older lantern. Same principle used in the current "adjustable" lanterns.
I thought using the pricker to control output caused soot build-up faster?
"I thought using the pricker to control output caused soot build-up faster?"
What makes you think that and where does the soot build up? Just curious.
In the generator? Hey, I'm a bit of a novice here - sorry if I'm off base.
"In the generator? Hey, I'm a bit of a novice here - sorry if I'm off base."
Generators get clogged up over time from byproducts in the fuel that don't vaporize with the fuel or breakdown with the heat. I haven't heard (so far) of generator soot/clogging issues coming from throttling the output with the pricker.
Thanks.
Rhubarb
Post by Rhubarb »
[QUOTE username=rcockrill userid=5959215 postid=1310004530]Okefenokee
Bless you!
  Image- Andy
Re: 228H red flakes in fuel
Post by ecblanks »
I've got a 200A and a 290A that both need peeled lining removed. I hate putting water products in my founts so I may try just knocking most of it loose with bb's and kerosene. I'm not so concerned about getting it all out, just the delaminated stuff.
Carlton
ICCC Member #1892
ecblanks wrote: Wed Apr 07, 2021 3:40 pm I've got a 200A and a 290A that both need peeled lining removed. I hate putting water products in my founts so I may try just knocking most of it loose with bb's and kerosene. I'm not so concerned about getting it all out, just the delaminated stuff.
Carlton, denatured alcohol will remove the brown fount liner. Give it a good long soak--a BB dance will help speed up the process too.
Post by ecblanks »
Ridge Runner wrote: Wed Apr 07, 2021 4:30 pm
That's an even better plan. Thanks!
Carlton
ICCC Member #1892
ecblanks wrote: Wed Apr 07, 2021 4:47 pm
No prob. I've done a few that way with good results.
Should've also mentioned--I filter the gunk through a paper towel and put the DNA back in the fount to continue soaking/dancing. You'll get a good idea as to when enough-is-enough once the brown crud stops coming out of the fount.
