What model is this
What model is this
Thank you so much
- Leviticus_Tomethreus
Re: What model is this
327 from I believe late 20s through to the 30s.
327 with over polished fount
probably used extra course steel wool to clean it
ICCC 957
The steel on coarse steel wool is the same hardness as fine steel wool. Same steel.probably used extra course steel wool to clean it
Big wool makes big scratches.
- Serious Colemanaholic
Nice find. I have the same from 1926 and it is a great runner
ICCC 1868
Perfection appreciation #10
Milspec 65252
ICCC 1868
Milspec 65252
Yes it 8 1
I used steel wool for clean this so it have some scratch
any advice for this
This is still doesn’t work a generator us death
Yes-absolutely. now is the time to have that fount plated, then you can use it as a mirror. The factory used nickel over brass. You could have it plated with copper, polished, and then plated with nickel. That will make it very smooth, and the shine will last.I used steel wool for clean this so it have some scratchany advice for this
Now that the plating is gone, you can eliminate the scratches, but it will take patience. Use 0000 steel wool and Mother's, which will then leave you with very fine scratches. You can then use a rag with Mother's to eliminate the scratches, or at least render them virtually invisible.
Know for future reference, the nickel plating is often very thin. Even 0000 is generally too abrasive, but if used gently enough, can help with cleanup. Even if you only used a rag with Mother's to begin with and started seeing dots as you polished, those dots would be where you burned through the nickel and the brass is starting to show.
