Prentiss wabers (brown bomber) questions
These lanterns seem to be pretty on par with Coleman’s but have a few differences. Attached are the first of few questions I have as this process comes long...the pump is straight forward, I think the check valve is stuck and I can’t get it to even move when put together.. also the generators seems comparable to a 200. And where do people find parts..fuel cap gasket etc?
Thanks as always
ICCC #1987
- Whitegas Extraordinaire
Re: Prentiss wabers (brown bomber) questions
It’s been a while since I pulled one apart but I seem to recall the fuel gasket was cork so I oiled it and it sealed.
For a generator I think you can modify a 220 or 200 generator?
They have a smaller pump cup than a Coleman so I tried a Tilley cup and it works ok.
Tgarner01 has been fighting with one recently.
ICCC #1987
ICCC #1987
Kraig
My apologies as I no longer pull apart working gpa as I’ve damaged more than one trying to help people out. I will dig through my photos and post what I can find.
With the unobtanium nature of these parts, why are you tearing this completely apart?
The pip may be stuck from sitting unused. Oil it up, reinstall and pump it up.
Check out this link from Erwin
http://www.eschaefer.de/hobbys/starkl/l ... nails.html
I will look at mine as like Toby’s being different, I thought the pip was part of the pump shaft
- Pancholoco1911
Coleman 275 Appreciation Syndicate #24 / Mil-Spec Ops, Bernz-o-Matic, and Sears Syndicates #58
