What Could This Be? Update: L220 Slant :)
CoolPro
Post by CoolPro »
:D Would appreciate help with identifying this one while I'm waiting for the current owner to return from the doctor's office. He says it's missing the generator. Can't see the collar, but the vent details and the fill cap might be clues. I think by the placement of the visible burner that it likely has two of them. Perhaps a 427?
CoolPro - Kelly In Alberta
Novice Fettler
Re: What Could This Be? 427?
Kelly that appears to be an L220 that's got a larger vent? If the valve assembly is missing, it could be a pricey replacement piece.
CoolPro
Post by CoolPro »
Tgarner01 wrote: Fri Jan 08, 2021 6:06 pm Kelly that appears to be an L220 that's got a larger vent? If the valve assembly is missing, it could be a pricey replacement piece.
Thank you - it would seem this is missing both the generator and valve assembly. Is it the fill cap that distinguishes it as an L220? The gentleman I'm dealing with over the phone did not seem to know what the lantern was, so what features could I ask him about that would identify it as an L220?
Cheers,
Novice Fettler
Kelly the easiest way to distinguish an L220/228 is be the angled valve/generator setup, these are also called slants. Looking closer at your picture I believe I see the valve assembly. I don't have a good photo showing the valve, generator setup, but this is what it would look like from the front.
CoolPro
Post by CoolPro »
Tgarner01 wrote: Fri Jan 08, 2021 6:24 pm Kelly the easiest way to distinguish an L220/228 is be the angled valve/generator setup, these are also called slants. Looking closer at your picture I believe I see the valve assembly. I don't have a good photo showing the valve, generator setup, but this is what it would look like from the front.
Thanks again - I assume if it was one of these, the open collar area under the globe support frame would be another key feature?
Kelly
Novice Fettler
CoolPro wrote: Fri Jan 08, 2021 6:28 pm
Kelly
It is, altho some Canadian 220A's had a funky collar similar, but that's not what I'm seeing here.
Here you can kind of see the slant design on this Frank I built.
CoolPro
Post by CoolPro »
I was able to download his posted photos at a bit higher resolution and expand them a bit. Does this look like the slant design opening on the globe support? Also, other photos show more detail on the fill cap and vent / vent nut.
Novice Fettler
CoolPro
Post by CoolPro »
Update - just spoke with him by phone - he says it has Coleman Quick Lite 2-29 (Feb 1929) stamped on it, and indeed the valve assembly is there, he says it just needs a generator - which I would think would take an R55? Think I'm gonna grab it from him. He's sending a few more photos which I'll post for confirmation of model.
Novice Fettler
Looks like a slant, has correct collar, poor photos.
looks like a mountie or signal vent on it ?
CoolPro
Post by CoolPro »
A 220? Or a 228?
Novice Fettler
CoolPro wrote: Fri Jan 08, 2021 7:28 pm A 220? Or a 228?
Appears to be a February of 1929 Canadian L220 Kelly. I don't know much about the Canadian versions to tell you what's correct or not. Maybe adelcoro will be along to help.
CoolPro
Post by CoolPro »
Tgarner01 wrote: Fri Jan 08, 2021 8:47 pm
Appears to be a February of 1929 Canadian L220 Kelly. I don't know much about the Canadian versions to tell you what's correct or not. Maybe @adelcoro will be along to help.
Thanks, Toby. I appreciate the ID.
Does anyone know if an R55 generator would work.in this slant?
Cheers,
Novice Fettler
CoolPro wrote: Fri Jan 08, 2021 10:01 pm
Cheers,
I've got one running an R55. Should be able to run an R55,Q99,Q77, or if threaded for it a T88
Nice Canadian slant find. The Q77 generator isn't too terribly hard to find. Mike at OCP may have them. I bought some from a member here a few years ago who said that he had a ton of them. I can't remember who it was though. Try putting a wtb ad in the classifies. You'll need the generator and the nut.
Scenicruise
Post by Scenicruise »
Did you get it? I saw it on kijiji and was tempted but was too busy to follow up on it / drive to town to get it. The vent looks nice even though it's probably not correct and probably a mountie vent?
Matthew
Coleman Quick Lite Crew #55
adelcoro
Post by adelcoro »
Canadian 220 slant with a wide brim vent
installed along the way should have the small dark green brimless ventilator
Agostino
ICCC 957
CoolPro
Post by CoolPro »
Scenicruise wrote: Sun Jan 10, 2021 6:47 am Did you get it? I saw it on kijiji and was tempted but was too busy to follow up on it / drive to town to get it. The vent looks nice even though it's probably not correct and probably a mountie vent?
I did get it - or rather my brother did - he picked it up for me. Nice gentleman that owned it - 75 years of life and despite an prosthetic leg, still full of vim and vigor. Obviously not original globe, missing genny & nut, and as Agostino and Toby have both poined out, somehow it got fitted with a replacement ventilator. Hoping there's no other issues. It's now my oldest lantern.
Anyone know where I could source a period-correct mica chimney?
Thanks to all for your assistance in helping me figure out what was in this rather obscure ad. Hoping to show you some fire from it in the coming months!
Cheers!
Novice Fettler
CoolPro
Post by CoolPro »
adelcoro wrote: Sun Jan 10, 2021 12:13 pm Canadian 220 slant with a wide brim vent
Agostino
Thanks Agostino - I've found the correct ventilator but still need to find a period-correct mica chimney and of course choose a generator & nut. Might need your help in figuring out what vent is currently topping this lantern once I get it in my hands.
Cheers,
Novice Fettler
Scenicruise
CoolPro wrote: Sun Jan 10, 2021 2:51 pm
Cheers!
Good to hear it went to good (collectors) home! I believe you'll need to get in touch with Fred Kuntz for a repro mica.
Matthew
CoolPro
Post by CoolPro »
Thanks, Matthew. I've sent an email to Fred.
Cheers!
Novice Fettler
adelcoro
Post by adelcoro »
CoolPro wrote: Sun Jan 10, 2021 2:52 pm
Agostino
Cheers,
Sure let me know
We can figure out if its Canadian or US
Agostino
ICCC 957
Dvan95
Post by Dvan95 »
That's a great score! The incorrect vent makes it unique :) Coleman's early stuff is their best!
-Dan
Coleman Quick Lite Crew #048
Dvan95
Post by Dvan95 »
-Dan
CoolPro
Post by CoolPro »
[/quote]
Cheers,
[/quote]
Sure let me know
Agostino
[/quote]
The L220 I bought is still safely with my brother in Edmonton, but I remembered I did have one shot of the (incorrect) vent that topped it. Can you ID the vent from this photo, Agostino? Some thought it might be a Mountie.
Cheers
Novice Fettler
CoolPro
Re: What Could This Be? Update: L220 Slant :)
Post by CoolPro »
Finally received this Feb-29 L220 lantern after my brother picked it up for me months ago. Should be a fun project...Anyone have a spare mica chimney and period correct generator and jamb nut they would be willing to send my way? Not sure about the fount, but I do have an orphan 10-28 spare slant fount just in case....
Cheers!
Novice Fettler
Nice find Kelly! OCP should have your generator and nut. Also Fred should be able to get you fixed up on a new Mica if interested. That fount appears to have had the entire bottom soldered... I'd look it over closely, luckily you have a spare 👍
CoolPro
Post by CoolPro »
Tgarner01 wrote: Sun Apr 04, 2021 11:00 am Nice find Kelly! OCP should have your generator and nut. Also Fred should be able to get you fixed up on a new Mica if interested. That fount appears to have had the entire bottom soldered... I'd look it over closely, luckily you have a spare 👍
Thanks! I have an R55 I will likely use for testing. Fred is a tough man to get ahold of - I've been trying for months! I am glad I have a spare fount, and will give this lantern a dunk test. Hope I don't need to switch, but it's nice to have the option.
Cheers,
Novice Fettler
CoolPro wrote: Mon Apr 05, 2021 12:55 pm
Cheers,
Sent you a PM Kelly
hikerduane wrote: Fri Jan 08, 2021 6:55 pm Looks like a slant, has correct collar, poor photos.
It still amazes me how today with the power of just cellphone cameras that people still take crappy pictures when selling something.
