Ceramic Burner Conversion?
Jeremy_71
Post by Jeremy_71 »
Has anyone ventured down the road of converting a petromax ceramic burner head assembly over to a coleman lantern? I have been looking at some parts and thinking about picking up a few pieces to try and take a 220 series and convert it to a single burner with the ceramic assembly off a petromax. Just curious if anyone has done this.
Jeremy Mitchell
"If you don't learn something everyday...You have wasted the day"
my Grandfather
Mil Spec Syndicate #2115
Re: Ceramic Burner Conversion?
No, but before going that last step and using a ceramic burner, I suggest you first try converting to just a single mantle. Then you may need to do some calculation or experimentation with using the ceramic burner to get the right air/fuel mixture. Changing too many variables at once often leads to frustration.
Will you be welding on an adapter to go from the smaller diameter Coleman burner and burner tube to the Petromax burner setup?
If you want a single burner 220, throw a milspec burner in there. Might be able to put a ceramic burner cap on there. I really don’t see the point though.
Levi,
Interesting idea, but that won't work because not only is the Petromax burner nozzle a much larger diameter, it's a male thread versus a female thread. I do not think swapping burner caps would be a simple project.
I don’t understands the point. Why need a single mantle 220 with ceramic burner cap? Jim, using them on a 220 would be just as hard, and then somehow make a 220 a single burner. That just seems like some W.C. Coleman engineering. Basically making your own model. Not even 220 at that point.
I've looked into making a single mantle 220 in the past, and I have confidence the air/fuel ratio can be worked out relatively easily... What I can not find a work around is no matter what you do the generator is placed where I want my mantle to be... In other words you can't center the mantle without changing something drastic... Then I just built franks to satisfy my want 😉
Jeremy_71
Post by Jeremy_71 »
I have played with the single burner aspect of a 220 before. I took the mixing chamber and rotated it and plugged off one burner tube hole. Therefore leaving one burner tube and aligned it centered over the gen. Changed the gen tip and cleaner to a 200 model one and it ran well. I lost that frank in a house fire in 2010 along with all of my others. I thought about it and was tossing around the idea of using the ceramic burner and chamber that it threads into from a petromax. The burner is ceramic and the chamber is brass. So I was thinking of cutting the burner tube on a 220 and adapting it over to the petromax pieces. Hopefully this clarifies my thought process.
Jeremy Mitchell
my Grandfather
200 on a 220/228 fount and 228 vent, and your done.
Wait, Toby just posted that...
