Need 290 lantern part
- Member
Hello Everyone,
I've been working on my 290 and I'm in need of a valve assembly 290A6571. Is the 290 an odd model for Coleman because I'm seeing that parts are not as easy to get for this model.
- Mister_Wilson
Re: Need 290 lantern part
What's wrong with your current valve?
Looking for 6-56 and 6-58 Birthday lanterns.
What John says.
These valves rarely need replacement unless they are physically unable to do the job from banging around or heavy service.
Usually a new fuel feed tube and maybe eccentric is all you need for the valve and maybe a little tightening of the packing nut if the fuel knob spins a bit freely.
BTW, generators, burner assembly's, fuel caps, fuel feed tubes, eccentrics, Schrader valves, and pumps can all be purchased new for this model from our sponsor, Old Coleman Parts.
- Member
The packing is bad.
- Member
Already checked with Mike. He doesn't have any.Chucker wrote: ↑Tue Jan 12, 2021 8:38 pm What John says.
Mike may not have the packing itself at the moment, but he has the ribbon which you can add to your existing packing. I suppose you could use the ribbon for the packing itself if need be, but haven't personally tried that.
I use the ribbon graphite packing on almost every GPA when they need it.
I have maybe a half dozen 'factory' size Coleman graphite packings (200 and 220 size) but the one's that seem to need it most are the odd-ball lanterns like Akron's, AGM's, and an occasional Kamplite.
I've got a new one Pm if interested
Syd
Looking for 8/56 + 9/59 lanterns
MilSpecOps #1956
275 Appreciation syndicate #1956
BernzOmatic Appreciation Club #56 GoldBond Collector #56
ICCC#1495
MilSpecOps #1956
ICCC#1495
