White gas heater storage - tank full or empty?
i am now a steward of a 512 catalytic heater; poll - store it with tank full or empty? will post pix soon promise
San Diego, CA
San Diego, CA
Re: White gas heater storage - tank full or empty?
For an experiment, put a cup of fuel in it, put it away for two weeks, and when you go back to it in two weeks, see if you can find a single drop of fuel left in it. I learned the hard way how fast fuel evaporates from these. They are not pressure appliances and aren't really sealed.
Jim is trying to say "no."
South Eastern Pennsylvania
San Diego, CA
San Diego, CA
Do you still have the original Coleman can? When I empty one, I keep one or two on hand, just in case I need to empty a lantern or stove.
nosir I would be learning the hard way about now.... left my empty can at Lake Henshaw this past weekend. oops.Gasman64 wrote: ↑Tue Jan 12, 2021 6:19 amDo you still have the original Coleman can? When I empty one, I keep one or two on hand, just in case I need to empty a lantern or stove.
So. Pour out the fuel and use it to fill all your lanterns and stoves
One in every public place...
ICCC #1338 IDITOS #2654
Member of CCF Chromostereopsis Club
Don't have quite the collection yet for all the fuel this thing holds but I was thinking about doing that. Trouble is I am not sure how much rust is in this guy's tank. Dude I got it from took real good care of it, says it was his pops' so I hope she's clean. it holds like half a gallon though we did run him a good bit.
San Diego, CA
San Diego, CA
So I came home with a bottle of Perrier, drank it then cleaned the bottle and followed with 99.9 alcohol rinse to get all the moisture out. Y'all were right! I only got about a pint out of there. I think the fuel evaporates faster than it burns off! i did note that there appears to be tiny pieces of what looks like fiberglass suspended in the fuel (probably wick) so needless to say it won't be going into the lantern. but NO rust yay! thanks all again for the info!
San Diego, CA
San Diego, CA
You could likely use that fuel in a lantern if you have a filter(felt) funnel. Either way, be sure the Perrier bottle is labeled accordingly, so no one grabs a gulp.
photos as promised.... don't know how to embed them but here are links.
https://ibb.co/j68bpzg
https://ibb.co/CVVsRrH
https://ibb.co/WgPr9m7
https://ibb.co/xsTGTJ3
https://ibb.co/vZX1WY3
https://ibb.co/Y8CGR6G
San Diego, CA
San Diego, CA
no filter funnel
San Diego, CA
San Diego, CA
