coleman lantern 220J
old_camper
Post by old_camper »
Hey fellas,
I'm new to the forum and need some advice. On a 220J lantern, the valve wheel turns very easily. Shouldn't there be some resistance when you open it? This lantern was given to me and was probably used a few times and then put away. I also own a 220F that works good.
Any advice is appreciated.
Re: coleman lantern 220J
" the valve wheel turns very easily. Shouldn't there be some resistance when you open it?"
If there is no leakage, then there probably is not an issue. If it just doesn't "feel right", then you might snug up a little on the packing nut.
old_camper
I appreciate the reply. I'll do that and see what happens.
Colmanaholic
Lanterns vary regarding how much effort it takes to turn the valve wheel. If the pump works and the lantern holds pressure, with fuel in the fount, give the pump a few strokes and look for a fuel leak around the packing nut on the valve stem. If no leak, add more pressure and watch for a leak. If you can pump it to higher-than-normal operating pressure without a fuel leak I'd say you're good to go with the easy turning valve. If you encounter a leak, just tighten the packing nut a hair. Tighten the packing nut just a tiny bit at a time until the leak stops
Welcome to the forum! +1 on the above advise. I have a few lanterns ( one being a 220J ) that the valve wheel turns very easy and I haven't had any issues. While other lanterns the wheel turns a little harder. Like said above, if you feel you need to tighten the packing nut a tad then do so but if it isn't leaking then I would leave it as is.
Trout
Post by Trout »
If the valve seat is in good shape you should have no leak at the packing nut even if the packing is loose/bad. You have to have the valve open a bit to get pressure/fuel down the valve stem to the packing. If you have a leak at the valve packing with the valve closed then you also have a bad valve seat/stem seal situation.
I would take the lantern outside,snug the packing nut, and with the 9/16" wrench at the ready, open the valve. I tighten the nut more if a leak occurs. Then I blow through vent to expel excess fumes
and light the lantern. YMMV
ICCC 1473
