burner screen material
- alciuffetelli
- Member
I've picked up a lot of lanterns lately and a few are missing the burner screens (just the screens). Any suggestions on what fairly easily obtainable material to use to cut out some of my own?
Al Ciuffetelli
ICCC#1977
ICCC#1977
- Hot_Diggity
Re: burner screen material
The replacements I've seen all appear to be stainless steel. The easiest place to find stainless steel screen is in the cooking section of the local grocery store. I used a small hand strainer to make the preheat screen for my 231ish single fuel preheat experiment. It's held up just fine.
Would water faucet aerator screens be available individually? They would be stainless and may even be cut to about the right size.
-Ken
-Ken
"In brightest day, in blackest night,
No evil shall escape my sight!
Let those who worship evil's might
Beware my power, Green Lantern's light!"
-Oath of the Green Lantern
"Any suggestions on what fairly easily obtainable material to use to cut out some of my own?"
Be aware that the typical burner screen is a somewhat coarse mesh made with thick (as compared to some typical screen material) brass wire. The function of the burner screen is to be a low flow restriction flame arrester. That notion needs to be factored in when looking for alternative materials.
You could get screens from this guy.
200A size:
220 size:
200A size:
220 size:
Just as a follow up, if the screens are missing, check the condition of the burner caps themselves to make certain they can still hold the screen without it falling out.
- alciuffetelli
- Member
Yes, Ken; I did just that when I needed one for my 237.
South Eastern Pennsylvania
Al,
I have used water faucet screens. One worked real well as a replacement for a Thermos lantern and it stopped that confounded popping. But it did restrict flow of a bit - so it is not as bright. It might be good to try to match the mesh size - which varied a lot over the evolution of Coleman lamps and lanterns.
I have also bought some replacement screens from OCP - they are the correct mesh and size and real easy to install.
- alciuffetelli
- Member
I made a nice burner screen from the mesh I bought off Amazon...and the old 236 pops just like you described your experience without a screen. Before I replaced the screen and tied on a new mantle, I test fired and it seemed to run smoothly...nice blue flame...but not now. I know the check valve isn't sealing properly, even after cleaning, and I'll replace that, but I can't see how this would make it pop like this. The mesh I used says the grid is 1mm, which looks about right to me, but we'll see if this continues when I get the new burner cap and screen from Mike.Phredd wrote: ↑Sat Feb 06, 2021 3:27 pm Al,
Al Ciuffetelli
ICCC#1977
ICCC#1977
- alciuffetelli
- Member
I finally got around to replacing the burner screen with the OCP part...and the 236 runs fine. When I went to tie on the new mantle, the "home made" screen I did with the material from Amazon disintegrated and fell out. This was supposed to be stainless, 1mm mesh...pretty sure this shouldn't have happened. Live and learn.
Al Ciuffetelli
ICCC#1977
ICCC#1977
