Fuel Cap Gasket ...
- Senior Member
Fuel Cap Gasket ...
Does anyone know the fuel cap gasket number for a 1972 200A 1 piece cap? Thanks.
- Leviticus_Tomethreus
Re: Fuel Cap Gasket ...
Ocp. Old Coleman parts website
Bob ICCC #1574
I suggest you buy more than you think you'll need of both the 1-piece as well as the 3-piece. They will get used.
Dang good advice right there!
Bob ICCC #1574
- Senior Member
Thank you for the replies..
Absolutely!
Andy
Mil-Spec Ops #199
Coleman Slant Saver #54
Coleman Quick Lite Crew #06
The Coleman Blues 243's #159
ICCC #1741
Mil-Spec Ops #199
ICCC #1741
Well, at this point, that link shows "unavailable product."
South Eastern Pennsylvania
and not all one piece cap gaskets are the same size....2 on the right are the same
Toronto, Canada
Toronto, Canada
Buy the 8-pack and do yourself a favor...
I destroyed one learning how to install it, and it seemed the Factory recommended just replacing the whole cap if it leaked. Those of us who can't bear to throw away an otherwise serviceable part will go through the effort to refurbish, which means having a few on-hand for when they're needed.
My technique involves oiling the new gasket and the stub on which it mounts, then using a socket of the appropriate diameter to force the gasket into place with the use of a bench vice and a patch of leather to protect the fuel cap. It's a slow process of cramming the gasket into place, but it does work well. If you can get it started by hand using a wooden dowel, that works well, too - but I found the vice technique to be less fussy.
Not oiling the pieces will result in you learning by destroying the first one.
Birthday 200A & 6/83 Last of the 220K's
I've replaced several one piece gaskets and haven't had any get damaged. I start it with a fingernail and then use the screwdriver blade on a tiny Victorinox pocket knife, which allows you to be precise when pushing down. The screwdriver blade is dull enough not to cause damage, especially since you're only pushing down at the edges. I do like the idea of a drop of oil though and may have to try that.
Here’s another one! Fuel Cap Gasket...in #9 becomes Buy the 8-pack and do yourself a favor,
What’s up with this?
That is odd as heck, OCP had them at the time. It would be like McDonalds running out of hamburgers.
Bob ICCC #1574
My wife stopped at Arby’s the other day to pick up dinner for us and they were out of roast beef
Covid.... Cows are out of work....
That is exactly how I feel right now. I am out of so many things that I vowed to never run out of. I hope to be getting some in next week. All I can tell you is that it is not my fault. I will give you one example. I was out of 200A globes. Finally got them in. I had 500 and they lasted less than a week. So I am back to waiting again. Almost all of them went to Japan. It has been like that for almost every product. Things are flying out the door faster than I can get them. Not sure what is going on. Maybe everyone is planning for the apocalypse.
Everyone is after those new patchesCigarMike wrote: ↑Sun Feb 14, 2021 8:52 pm That is exactly how I feel right now. I am out of so many things that I vowed to never run out of. I hope to be getting some in next week. All I can tell you is that it is not my fault. I will give you one example. I was out of 200A globes. Finally got them in. I had 500 and they lasted less than a week. So I am back to waiting again. Almost all of them went to Japan. It has been like that for almost every product. Things are flying out the door faster than I can get them. Not sure what is going on. Maybe everyone is planning for the apocalypse.
