CQ Issues
- Leviticus_Tomethreus
CQ Issues
Hey all! Sad day. My CQ has been out of operation for a while. Put Toby through enough trying to get it working again (His tricks didn’t work) so I’ve come you the forum for help. It’s running super lean. Super. Fuel cap seals good, fuel tube is clear, genny is just fine, fuel is fresh crown. I can’t figure out what’s going on. Pumping has zero affect in flame size. Anybody know what’s going on?
Re: CQ Issues
What generator are you running? If you're running an R55, make sure that the pricker wire is completely pulling out of the tip when you bring the cleaner lever down. It sounds like you have a restriction somewhere. How about maybe a small chunk of something stuck in the valve body itself, not letting enough fuel pass through the valve?
Re: CQ Issues
Was the genny tip it looks like. Hmm. Lol. Now my G has a leaky valve. Ugh!!
- Senior Member
Re: CQ Issues
don't some need a washer under the plate ? might be restricting air flow.
bob
bob
Re: CQ Issues
What washer under what plate?surffisher60 wrote: ↑Sun Feb 14, 2021 7:39 pm don't some need a washer under the plate ? might be restricting air flow.
bob
Re: CQ Issues
Some of the newer R55 are backwards on the spinner. Make sure with young eyes or a magnifying glass which is right and if the tip cleaner is still working .
Next easy steps is some compressed air through the valve and into the fount
(and - for those who have asked - avatar from postcard and says "Coming Home by Rail". https://c1.staticflickr.com/5/4595/2743 ... be00_z.jpg
Re: CQ Issues
Valve is fine! Q77. Pricked the genny and it spray fuel. My pricking while it was off just seemed to do nothing...
- hikerduane
Re: CQ Issues
Try restricting air, poke a finger around the opening of the air tube. A couple of my lamps don't like a lot of air.
- Hot_Diggity
Re: CQ Issues
I'm thinking along the same path as Duane. You could be barking up the wrong tree. Sounds like you have the fuel system covered, but you didn't mention if you had run a brush through 100% of the air side of the system. Could be that the symptoms you see as lean are in fact rich, but are masked by lack of air.
And how do you know the generator is good? Did you run it on something else?
Re: CQ Issues
If you could post a picture of the CQ running with the usual pressure, without the mantles, we'd see how lean that really is.
Did you check that its not picking up some air in the fuel pickup tube? That might make it appear lean, perhaps with a little pulsing as well.
Re: CQ Issues
Yeah. Tubes are cleaner. Ran the genny in something else. Lamp runs now. There black spots on the mantle. That’s the new issue.
- Hot_Diggity
Re: CQ Issues
I get black spot with kerosene, but have never seen it with Crown Fuel. Let it run for an hour and see if the spots get
smaller. They should burn off if all is in tune.
Did you find some webs or nests in the air tubes? I have one that I blew out with 150PSI of shop air, and when I took the burner off you couldn't see light through all the mesh of webs and nests. The air did little if anything to disturb them. Fuzzed end of a small cable is what I use now. Leaves the tubes nice and clean.
Re: CQ Issues
Yeah I brushed through them. Had it lit two hours yesterday and the black spots never changed.Hot_Diggity wrote: ↑Mon Feb 15, 2021 3:38 pm I get black spot with kerosene, but have never seen it with Crown Fuel. Let it run for an hour and see if the spots get
- Hot_Diggity
Re: CQ Issues
It burns bright? Sounds normal? Black spots aren't getting bigger? If they're staying the same size you could try hitting them with a pencil torch and see if that burns them off. Could just be something had gotten on the mantles and they're contaminated. Is it on both mantles? Might still be running rich. Worn generator tip?Leviticus_Tomethreus wrote: ↑Mon Feb 15, 2021 3:43 pm
Pictures sure would help Levi, and would save a lot of questions. This is how my kerosene spots looked.
Re: CQ Issues
Was never rich. Black spots in three different pairs of mantles.Hot_Diggity wrote: ↑Mon Feb 15, 2021 3:59 pmIt burns bright? Sounds normal? Black spots aren't getting bigger? If they're staying the same size you could try hitting them with a pencil torch and see if that burns them off. Could just be something had gotten on the mantles and they're contaminated. Is it on both mantles? Might still be running rich. Worn generator tip?Leviticus_Tomethreus wrote: ↑Mon Feb 15, 2021 3:43 pm
- Hot_Diggity
Re: CQ Issues
Did you try Duane's trick with partially blocking the air tube?
Re: CQ Issues
No. How would I block it long enough to affect it?Hot_Diggity wrote: ↑Mon Feb 15, 2021 4:39 pm Did you try Duane's trick with partially blocking the air tube?
- hikerduane
Re: CQ Issues
Poke a pinkie up the air tube, only need to partially block flow, nearly instant results. The couple I had to do that to ran a whole lot brighter. Used some rolled up foil or metal sheeting after I tried a finger.Leviticus_Tomethreus wrote: ↑Mon Feb 15, 2021 4:43 pmNo. How would I block it long enough to affect it?Hot_Diggity wrote: ↑Mon Feb 15, 2021 4:39 pm Did you try Duane's trick with partially blocking the air tube?
Re: CQ Issues
Here's Levi's photos he's too lazy to load...Hot_Diggity wrote: ↑Mon Feb 15, 2021 3:59 pmIt burns bright? Sounds normal? Black spots aren't getting bigger? If they're staying the same size you could try hitting them with a pencil torch and see if that burns them off. Could just be something had gotten on the mantles and they're contaminated. Is it on both mantles? Might still be running rich. Worn generator tip?Leviticus_Tomethreus wrote: ↑Mon Feb 15, 2021 3:43 pm
- Whitegas Extraordinaire
Re: CQ Issues
Mantles aren't terribly full / puffed out?Tgarner01 wrote: ↑Mon Feb 15, 2021 6:20 pmHere's Levi's photos he's too lazy to load...Hot_Diggity wrote: ↑Mon Feb 15, 2021 3:59 pmIt burns bright? Sounds normal? Black spots aren't getting bigger? If they're staying the same size you could try hitting them with a pencil torch and see if that burns them off. Could just be something had gotten on the mantles and they're contaminated. Is it on both mantles? Might still be running rich. Worn generator tip?Leviticus_Tomethreus wrote: ↑Mon Feb 15, 2021 3:43 pm
Pretty old generator too.
Re: CQ Issues
What do you mean generator is old? Insides look brand new!Whitegas Extraordinaire wrote: ↑Mon Feb 15, 2021 6:43 pmMantles aren't terribly full / puffed out?Tgarner01 wrote: ↑Mon Feb 15, 2021 6:20 pmHere's Levi's photos he's too lazy to load...Hot_Diggity wrote: ↑Mon Feb 15, 2021 3:59 pmIt burns bright? Sounds normal? Black spots aren't getting bigger? If they're staying the same size you could try hitting them with a pencil torch and see if that burns them off. Could just be something had gotten on the mantles and they're contaminated. Is it on both mantles? Might still be running rich. Worn generator tip?Leviticus_Tomethreus wrote: ↑Mon Feb 15, 2021 3:43 pm
Re: CQ Issues
Even when I am not polishing like jewelry they look a tad cleaner?Leviticus_Tomethreus wrote: ↑Mon Feb 15, 2021 6:45 pmWhitegas Extraordinaire wrote: ↑Mon Feb 15, 2021 6:43 pmMantles aren't terribly full / puffed out?Tgarner01 wrote: ↑Mon Feb 15, 2021 6:20 pmHere's Levi's photos he's too lazy to load...Hot_Diggity wrote: ↑Mon Feb 15, 2021 3:59 pmIt burns bright? Sounds normal? Black spots aren't getting bigger? If they're staying the same size you could try hitting them with a pencil torch and see if that burns them off. Could just be something had gotten on the mantles and they're contaminated. Is it on both mantles? Might still be running rich. Worn generator tip?Leviticus_Tomethreus wrote: ↑Mon Feb 15, 2021 3:43 pm
Doesn't look like a full fettle too.
When was the last time a 77 or that style nut was made? Thinking before Murff was born!
Re: CQ Issues
It works just fine in my 327. The Q99 in my 327 was also tried in this and nothing changed.Whitegas Extraordinaire wrote: ↑Mon Feb 15, 2021 6:54 pmEven when I am not polishing like jewelry they look a tad cleaner?Leviticus_Tomethreus wrote: ↑Mon Feb 15, 2021 6:45 pmWhitegas Extraordinaire wrote: ↑Mon Feb 15, 2021 6:43 pmMantles aren't terribly full / puffed out?Tgarner01 wrote: ↑Mon Feb 15, 2021 6:20 pmHere's Levi's photos he's too lazy to load...Hot_Diggity wrote: ↑Mon Feb 15, 2021 3:59 pmIt burns bright? Sounds normal? Black spots aren't getting bigger? If they're staying the same size you could try hitting them with a pencil torch and see if that burns them off. Could just be something had gotten on the mantles and they're contaminated. Is it on both mantles? Might still be running rich. Worn generator tip?Leviticus_Tomethreus wrote: ↑Mon Feb 15, 2021 3:43 pm
Re: CQ Issues
Levi get a new generator and post again after the change from old to new. That jet could be worn
Re: CQ Issues
I switched gennys with my 327. Q77 runs just fine in the 327. Q99 runs slightly dimmer in the CQ.
- SteveRetherford
Re: CQ Issues
sometimes after a good cleaning , when you fire it up the inside of the burner tubes gets "scale" that fall off n partialy block the burner screens resulting in similar looking mantles ....
![[DrSteve2]](https://d28lcup14p4e72.cloudfront.net/50792/4217452/DrSteve2.jpg)
