Knob doesn't effect light output..
- Senior Member
What would cause a 220 knob not to control the light output? The knob shuts it on and off but nothing else, Thanks.
- Leviticus_Tomethreus
Re: Knob doesn't effect light output..
They aren’t adjustable lanterns. They’re supposed to run wide open. You can play with the pricker lever to dim it but I don’t ever do that. It’s either BRIGHT, eh, and even more eh.basenjib123 wrote: ↑Sun Feb 14, 2021 11:16 pm What would cause a 220 knob not to control the light output? The knob shuts it on and off but nothing else, Thanks.
- Senior Member
Oh ok, LOL...can you tell that I'm new to this?
A little bit. All models after the 220/200a were discontinued are adjustable.
- Masseyhouse
- Member
We are all "new" in some way or another.
It always good to ask questions, so many have so much to share.
Deacon Jeff at Masseyhouse@yahoo.com
If you want it dimmer, use lower pressure. However, don't open the fuel cap to bleed off excess pressure while running. An unintended and unwanted fireball could result. I suggest starting with very low pressure, then adding a pump or two until you have the desired light output.
"What would cause a 220 knob not to control the light output? The knob shuts it on and off but nothing else, Thanks."
For practical use, you adjust the output using the cleaning lever. I learned that way back watching my dad. The new "adjustable" lanterns actually do the same thing to adjust output.
- Senior Member
Thank you for the replies
