Old kero topic
salukispeed
Old kero topic
Post by salukispeed »
I came across a better deal than normal 8.99 and Just put up 6 of gal of Klean Heat Kero substitute. Basically K1 water clear kero with less smell I painted 6 clean steel Crown CF gal cans blue for Kero ID and sealed them tightly. I figured better than storing in the plastic bottles. Would anyone care to guess the shelf life to be expected .. I only go thru 4 gal in a winter season but want reserve.
ICCC 1868
Perfection appreciation #10
Milspec 65252
Re: Old kero topic
Kero works forever in wickies. Couple years in gpa
Stovie
Re: Old kero topic
Post by Stovie »
I've 10 year old Klean-Heat in the original jug that is just fine. I keep that indoors.
I have found that Kero and similar stored in the plastic in a garage paint cabinet with wide seasonal temperature swings does strange things to the container, it seems to outgas or evaporate some and cause the container to implode some.
Re: Old kero topic
With absolutely minimal air space in those cans, likely it'll last many years before losing energy or being of any concern.
I don't know how many years it takes sitting in a wickie where the kero is exposed to air due to it not being sealed, but kero will develop the most foul stench you could imagine. It's that point that you won't burn it or want anything to do with it. Get a drop on yourself and you'll be fighting to get it off. Much like the Avon cologne in a Coleman lantern bottle.
salukispeed
Re: Old kero topic
The stench of wild country!! cologne???
ICCC 1868
Milspec 65252
Re: Old kero topic
I don't know the name. It smelled OK in the bottle, but putting a drop on me, it reacted with my chemistry and developed an awful stench. Perfect stuff to ensure social distancing.
Re: Old kero topic
I've been using 4+ year old kero, still in it's original plastic container, in an Aida lantern, a 237A lantern and Aida No.100 stove and still works fine. I do like the painted metal Coleman CF can, however. Been thinking about doing that, too. The rectangular cans store better along side my CF cans.
Re: Old kero topic
It may not be the kerosene that causes the smell, as much as the fungus that grows in it. I knew this fungus grew in diesel fuel, and caused all sorts of trouble when we switched to JP8, since it loosened all the fungi in the fuel tanks and stopped up filter after filter with it. What surprised me was to find fungus growing in some of my diesel injector test equipment, in very expensive calibration fluid. In an absolutely stable temperature environment, with no light, and no other contaminants (school setting, no outside diesel contamination, calibration fluid only) the reservoir of one of my lab machines had a big rubbery glob of fungus in the reservoir. I think all kerosene stinks, and only run Kleen Heat in the inside lamps.
Fungus and water are why I have my little Du-Bro hand crank pump to remove kerosene from lamps as well as filling them. Run the kerosene through a filter funnel and if it's at all questionable add it to the mix that I burn in the 237.
I have some kerosene in the barn from 2012, and like Levi says, it works fine in wickies. I bet it'd be fine in GPA with a little Amish mix of CF to keep the black spot away.
JLush
Re: Old kero topic
Post by JLush »
So here's a semi-related question: In my experience CF pretty much has an unlimited shelf life whether in a can or a GPA. Would adding CF to kero (aka Amish blend) help to preserve the kero?
...On the lookout for a 3/61...
Re: Old kero topic
JLush wrote: Sat Feb 20, 2021 3:13 am So here's a semi-related question: In my experience CF pretty much has an unlimited shelf life whether in a can or a GPA. Would adding CF to kero (aka Amish blend) help to preserve the kero?
An excellent question. I have no idea what it might do, but I know Amish mix will fix old kerosene that makes black spots on mantles. The density of the fuels are very close. This probably helps them mix easily.
Re: Old kero topic
I'd be reluctant to add any CF to kero for a wickie. I don't know what's in Sta-Bil, but wonder if that would help preserve kero. Maybe the Sta-Bil folks would know and would share the info.
Guff
Re: Old kero topic
Post by Guff »
Below is a copy of Coleman lantern instructions for a 249 lantern dated 4/42. It says to not expose the kerosene fuel to the air or light.
So I suppose if you store it in an air tight opaque plastic container it should be ok. My personal storage preference would be a metal container.
Most clear kerosene in small quantities, 1 litre to 5 litres, is invariably sold here downunder in clear plastic containers, and only the 20 litres in metal drums. So maybe the clear containers should have a use by date on them, if exposure to light degrades the kerosene??.
Keith.
SteveA
Re: Old kero topic
Post by SteveA »
I like the paint the empty camp fuel can blue idea!
Re: Old kero topic
Post by Dmacp »
as long as it is still clear and liquid my 237 laps it up. If it's really bad I dilute it some with fresh stuff. Always use a funnel filter too.
Re: Old kero topic
I've added CF many times to 'old' kero to perk it up in GPA's. As mentioned above, never in a wickie however.
