SMP Mil-Spec Air Tube Plug
Tearing it down for rust removal and I noticed it does have the plug in one of the tubes. It also appears that it has a hole in it, so not fully blocked.
Does it help with performance, air/fuel mix by removing it? The other one lit right up and ran fine. Assuming the plug is still in place.
Mil-Spec Ops #1988
Mil-Spec Ops #1988
- Leviticus_Tomethreus
Re: SMP Mil-Spec Air Tube Plug
Plug is for high altitudes. If it’s at a high altitude remove it. I can’t figure out how to get it out. I hear the lantern gets louder without it.
On mine it appears there is something like a spring clip keeping it in place. Would imagine I could hook it through the hole to pull it out? As long as it runs (once I get it back together) I am fine with leaving it in. Just that I have seen a few posts talking about removing it. Since I am in Florida high altitude is not an issue.Leviticus_Tomethreus wrote: ↑Fri Feb 19, 2021 11:33 pm Plug is for high altitudes. If it’s at a high altitude remove it. I can’t figure out how to get it out. I hear the lantern gets louder without it.
Mil-Spec Ops #1988
Mil-Spec Ops #1988
"Does it help with performance, air/fuel mix by removing it?"
Have you fired it up and see how well it works?
- Hot_Diggity
I'm at nine feet above sea level and have an Armstrong with the plug removed. It is loud, and bright as a tiny star, or so reports #1 Son, who came home one night when I had it hanging on the porch.
The plug in mine was a simple cup that was a press fit into the tube. I knocked it sideways in the tube and could then grab it with a needle nose pliers.
If you are going to use RUG as the fuel, removing the plug might help with the combustion.
RUG is a somewhat 'heavier' fuel than Camp or Coleman Fuel. It needs slightly more air in the mix to burn completely.
- Title: ECCENTRIC BLOCKHEAD
It is press fit into the intake tube. You can pick it out with a sharp instrument.
This may be used to open up a clean air tube, if the other one becomes blocked by an obstruction in the field (that can't be easily removed).
ICCC #889 - Connoisseur of Time, Friends, Leisure, & Coleman Altoona, PA - The Mountain City - Near The Eastern USA Continental Divide
Of the two this one had the most rust issues, pump cup dried out and the check valve was sticking so I decided just to tear it down instead of trying to light it.
Mil-Spec Ops #1988
Mil-Spec Ops #1988
No plans on running RUG in it unless an emergency situation.
Mil-Spec Ops #1988
Mil-Spec Ops #1988
Same here as far as RUG. I do sometimes get above 7,000 Ft. and think that that is the point to remove the plug. I am usually at sea level oto 3,500 and run with the plug. The lantern that I got with out the plug I replugged it. They run good when diled in and are fun making good light. They will run almost all night if need be.
RMW
RMW
I was pretty impressed with the light compared to my 275. One night I'll have to do a side by side comparison for light output and run time.
Mil-Spec Ops #1988
Mil-Spec Ops #1988
Removing the plug can help performance when the orifice enlarges from normal use as well.
Since a larger orifice gives you more fuel, more air is required to even out the burn. So, you can extend the life of the gen and orifice.
Any idea as to the useful life of the generator?
Mil-Spec Ops #1988
Mil-Spec Ops #1988
Yes, a member found paper on that a few years ago and as I recall it was 700-800 hours using Naphtha.
This would include cleaning the orifice occasionally of course.
Thanks! By the looks of them they have been rarely run plus there were two new generators in the box. I'm good for quite some time.
Mil-Spec Ops #1988
Mil-Spec Ops #1988
