200A How to fit in Clamshell case
greatfactor
Post by greatfactor »
May I ask for advise
About Yellow clamshell case size of 200A
Can anyone show the correct direct to fit lantern in this case
I try many direction but it seem not right
Re: 200A How to fit in Clamshell case
is it a tall vent 200a? Those don’t work. Only short vent 220/228 and 200a work in clamshell. Guillotine cases are for tall vent.
greatfactor
Leviticus_Tomethreus wrote: Sun Feb 21, 2021 1:04 pm is it a tall vent 200a? Those don’t work. Only short vent 220/228 and 200a work in clamshell. Guillotine cases are for tall vent.
Low vent
greatfactor wrote: Sun Feb 21, 2021 1:04 pm
Low vent
Should just be able to slide it in there. Oh! Might be because you need the 200a puck inside rather than 275 or 220 puck.
Ridge_Runner
Post by Ridge_Runner »
Should slide in like this:
Edit: If you have an accessory safe on the bottom of your 200A, you’ll need to remove it.
greatfactor
Ridge_Runner wrote: Sun Feb 21, 2021 2:14 pm Should slide in like this:
Thanks a lot.
Ridge_Runner
greatfactor wrote: Sun Feb 21, 2021 3:25 pmThanks a lot.
You’re very welcome 🙂
And, welcome to the CCF!
