Broken valve stem? No problem!
dbosch
Post by dbosch »
So I took it as a personal challenge. A 236 valve stem with the splined end broken off. Could I recreate the end?
Turned down the end on the lathe, added the #4-40 threaded hole and then the fun began.
The end has 13 splines. I measured the circumference of the 3 jaw and marked it for 13 indexes. I don't have an indexing head and anyway, 13 splines is every 27.7degrees. I set up a cutter insert sideways in the tool post and slowly broached the spline set using the cross slide.
Dan B.  ICCC #100
The Texas Dust Bowl
Re: Broken valve stem? No problem!
Looks good Dan! I wondered how a guy would go about broaching those splines. Thanks for sharing 👍
gwillmot
Post by gwillmot »
Very impressive, although the description of how it was done was as clear to me as if spoken by a Wookie ........ glad some of us are so talented!
Still Crazy After All These Years
Mark 16:16
Well done! I like your simple approach to cutting the splines!
Neat, Dan. Atlas?
dbosch
Post by dbosch »
Yessir. The later 6 inch one with the roller bearings.
Dan B.  ICCC #100
The Texas Dust Bowl
JLush
Post by JLush »
Well done sir! My father did some amazing work on a 6" Atlas so it's nice to see that the machinist spirit is still alive.
...On the lookout for a 3/61...
One of the nicest lathes Atlas made was the 6" with the Timkin roller headstock. I have a plain bearing one that I used for some years, but it had to be put into storage to make some room in the shop, mainly because machines were starting to bump into each other. I don't know of any other real lathe that will cut more thread counts as the little Atlas until you get up to Monarch EE territory.
mgmlvks
Post by mgmlvks »
N I C E . I could only hope to have that vision . Thanks for sharing!
MYN927
Post by MYN927 »
That was a great job done. I was pondering earlier how can I make a 13-splined hole in a brass insert that could fit into the splined valve stem.
JD37B
Post by JD37B »
Very clever! Thanks for sharing.
CaptainFantastic
Title: Coleman Helvetica (CH)
Post by CaptainFantastic »
I really like it when you talented guys share this stuff. Amazes me, it really does. I wish I had 1/100th the skill or knowledge, and the equipment, to do this stuff.
Post by Dmacp »
that's a neat trick. I will have to try to remember it.
MYN927
Post by MYN927 »
There aren't any 13-splined stems of similar diameter that I could find on any other stuffs besides the Coleman valves.
Faucet valve stems are too large.
Pretty close would be the imperial 12-splined bit.
Looks like there's no escaping the custom broaching task.
Depending on the handle material; you could grind a custom single pointer from HHS?
dbosch
Post by dbosch »
High speed steel? Sure as long as the material being cut is softer than the cutter.
Dan B.  ICCC #100
The Texas Dust Bowl
I did state "depending on the materiel" and HSS is great for most things, so why not? Carbide and other cutter materials are very good, particularly for extended life and speeds of cut, but unless you are dealing with extremely hard materials, HSS does the job.
When I make these kind of things I usually use a small center drill or very small countersink spinning in the mill and index with my rotary table. Both of those tooling items are made from HSS. Plenty good for anything up to mild steel, and they are quite inexpensive.
Dan had to do it a little harder way, but got great results. Yes, HSS will work in the way he did it too, and there is less chance of it breaking if you get into materials harder than brass or aluminum. Carbide is not likely to break on the cutting stroke, (going from right to left as seen in Dan's pics) but could break on the reverse stroke that returns the tool back to its starting position if dragged back in the cut. Carbide is that brittle that a little bit of drag backwards against the under side of the cutting edge can pop off little chips on the top of the tool, (the cutting edge). It is a very superior cutting material, and will actually cut HSS, but it has to have the pressure of the cut put only on the actual cutting edge if the tool is to last. With HSS, or even hardened high carbon steel, you don't have this situation, but you don't have the tool life in hard materials, either.
StanDahl
Post by StanDahl »
Wow! I'm glad someone can do that, I'll be sending you a couple of those soon! :cf_heeheehee:
dbosch
Post by dbosch »
The process is somewhat slow. I took 0.005in bites in each groove until I went around all 13 grooves. I probably went around the shaft 6 times (6x13=78 cuts). Once I got into a rhythm, it wasn't that bad. I should have slowed up and sneaked up on the fit at the end, but the slip-fit of the spline on the valve wheel was identical to a stock Coleman valve. I got lucky. Trying to hit a tolerance while taking a larger cut never works out as you think it will.
The carbide cutter is just a stock 60degree cutter. I could have ground a narrower cutter but this one was close enough. I need to play with this some more.
Dan B.  ICCC #100
The Texas Dust Bowl
