F/A tube problem?
F/A tube problem?
Just refurbished my new 202. And when i light it - even after a 10 min warmup - it is a bit yellowish and not bright when the valve is fully open. It gets a brighter when I close the valve most of the way.
I think the problem is the F/A tube maybe clogged or spring not in correctly??
Note i did not remove the valve assembly because the fount is brass and from 1954....
Re: F/A tube problem?
If it gets brighter when you mostly close the valve it sounds like it's running rich... Which would not be a F/A tube issue. Try getting it running like normal with the valve all the way open and try slowly turning the cleaning lever and see if it gets brighter before getting dimmer. This will be touchy but may indicate a rich issue. Are you getting any flames outside the mantle?
The F/A tube shouldn't cause that problem.Running too rich, either tip is too big or air restricted somewhere.
It is an old nickle plated generator. I'll try swapping out the orifice from a new generator.
K
And if you haven't already, you might physically clean out the air tube, like with a brass .45 cal. cleaning brush or even a small bottle brush.
air tube - i cleaned it but will double check.
JLush
Post by JLush »
Perhaps a silly question but what are you using for mantle? When I got my 202 cleaned up and put back together I used a Peerless 24-A and it was never as bright as I thought it should be. Replaced the 24-A with a 21A and it's nice and bright with just a hint of overburn if it's pumped up too much.
ICCC #2025
FIXED - it was the F/A tube spring...
Thanks to everyone for tips on fixing this issue. Changed generators, cleaned air tube, etc... no help.
So I fetteled the only part I had not already worked on. I removed the valve and f/a tube from the fount. And regardless of whether the valve was open or closed, the f/a tube pricker did not move much. So I removed the f/a tube from the valve and found that the spring was really compressed and had no 'spring' left. I sonicated the f/a/tube and pricker and spring, cleaned them with carb cleaner, and blew out the f/a tube with compressed air. And re-assembled the lantern and ....drum roll - it works great!! Photos below of the pricker with valve open or closed, the spring (blackish) right next to a spring i took out of a 220F. And of course - a photo of the lantern shining bright.
holliswood
Post by holliswood »
Looks fantastic!! Nicely done 👍🏻
-Fred
ICCC Member #1871
MilSpec-Ops #1278
Coleman Quick Lite Crew #41
CANADIAN BLUES SYNDICATE #57
Coleman Slant Saver #65
snipesfred on Insta
Big Ferd on YT
