Valve stem assembly leaks
jamie200a+
Post by jamie200a+ »
Hi guys and gals, I am new to the hobby. I have a 1955 200A that I am trying to restore. My problem is: the valve stem assembly does not shut off fuel. When pumped up, it continues to feed fuel up through the generator, regardless if the valve stem is on or off. Any suggestions for help would be greatly appreciated. Thank you for taking the time to read my “rookie” issue.😊
Re: Valve stem assembly leaks
You might search the forum for "valve tip" and similar for previous post about valve tip leakage and wear, and how to fix.
jamie200a+
Ok!.. thank you for your response.👍😊
Check for crud on the valve seat while you're in there. Not common, but it does happen.
Yeah, that can happen when a previous owner thinks a lantern should shut off like a light switch and they keep cranking down on the valve stem. It can take up to a minute or two for a lantern to completely extinguish. The reason is that there is still fuel in the generator vaporizving and feeding fuel to the mantle. When it's cranked down, a groove gets worn into the soft brass of the valve stem cone, and often where it enters the valve.
On the chance that there's debris preventing shutoff, you could try removing the generator, opening the valve, pumping up a bit to get a gusher of fuel through the valve, shut it off and reassemble. Although I really suspect it's a grove worn in as that is generally more common.
Here's one thread on addressing a groove in the stem.
https://www.colemancollectorsforum.com/ ... =5&t=10485
jamie200a+
Thanks guys, I will try your suggestions and keep my fingers crossed. LOL.😊
Stovie
Post by Stovie »
If it's just the stem needle that is buggered it's a pretty easy (and effective) repair to make. Probably something that should be done anyway as part of "fettling" in general, brass is very soft and prone to this. But, by the same token since it is so soft it cleans up quickly.
Broad is the path that leads to destruction.
Especially those red headed broads, they are a sure path to ruination.
jamie200a+
Ok! It appears as if a few of the stem threads are damaged/ stripped.Can I “ re-tap” the threads?
Stovie
Valve stem leaks
Post by Stovie »
I believe the issue at hand here most likely isn't the threads, but rather the needle & seat. The "pointy tip" as it were, gets gouged, or has groove damage. Can try running a thread chaser over the threads I guess. Maybe just purchase a replacement stem.
jamie200a+
Ok! Thanks again for the advice.😊
Stovie
Valve stem assembly
Post by Stovie »
Pics, man, we need pics!
