I am cleaning up a 500 speedmaster. I followed murfs (awesome) how to on the tear down, I am wondering about the picker spinner. It is seized in the up position and I didn't want to break the handle. Usually we leave that alone on lanterns, so thought I would ask what the best way to unseize that picker?
I had to remove the lever and packing on a 500 in order to repair/solder a broken fuel line. Removal destroyed the packing in my case. So if heat and a penetrate work all the better. The good news was at the time OCP had a replacement lever/nut/packing that worked excellent.
Taco912 wrote: ↑Fri Apr 02, 2021 5:50 pm
Thanks for the info. I will try to heat and penetrating oil before I take the next step. I will look at ocp to see if there are parts just in case.
Thanks
Pb
Paul Barrette
Coleman Quick lite crew #52
Milspec Syndicate #00085
I just did one. I removed the nut and slid it out then just put a single drop of penetrating fluid where the rod enters. Let it sit for a minute and with very gentle pressure it broke free. Then just tighten the nut back down. I wouldn't use heat, the backside is soldered where the tube enters and you will melt it in two seconds.
pagrey wrote: ↑Fri Apr 02, 2021 7:51 pm
Hi Paul,
I will try that. I haven't touched it yet. Thanks
Pb
Paul Barrette
Majicwrench wrote: ↑Fri Apr 02, 2021 11:05 pm
I would use a torch,( I did on one yesterday) they are often stuck and loosen right up with a little heat. Just don't over do it.
That is not the pricker, that is for the f/a tube
Yes, that is correct. It looked like the picker stem but connects to the fa. I will try the heat next.
Thanks
Pb
Paul Barrette
Ok thanks for the advice. So far....I unscrewed the nut and can set there graphite is ok.
I put in penetrating oil and left it over night. This morning I checked, and it is still stuck. I put more it this morning. I think the oil is not going to cut it. Maybe boiling in citric? The stove works like it is now, the risk is ruining the valve, which is probably hard to replace.
Pb
Paul Barrette
Just one man's opinion here, and it's just that... I've heated a lot of packings to free them up and I've resoldered several bungs and the heat needed to free that lighting lever is not nearly as much as it will take to reflow the solder in the fount bung. In fact I normally just use a small butane torch for heating my packings to get them to release.... If for some reason you're still worried remove the assembly from the fount and give it all the heat you want clean the F/A tube while you're there.
Tgarner01 wrote: ↑Sat Apr 03, 2021 1:37 pm
Hey toby,
I removed the valve from the fount to clean up the fa tube. Maybe I am confused here but from above, it looks like there is a solder joint somewhere, but if it is the bung, that is not a problem because I removed the valve. Am I missing something?
Thanks
Pb
Paul Barrette
Hey toby,
Thanks
Pb
I was assuming you were trying to heat the assembly in the fount and that was the worry of loosening the solder on the fount bung, now I'm realizing the worry is on the fuel line solder joint? If I remember correctly this is hard soldered and would be less of a worry, but I could be wrong... Normally am as is apparent above
Thanks for all the great advice all! I decided to wrap the back end with wet cloth as @taco912 suggested.
I touched it with the torch for a few seconds. That loosened it up right away.
Pb
Paul Barrette
paulbarrette wrote: ↑Sat Apr 03, 2021 2:59 pm
Pb
Glad that worked, love the smell of success first thing in the morning.
