BernzOmatic profane ??
I have been looking to add one of these globes to my collection for awhile but like everything else they are high $$ right now. Anyway for about the same price as the globe itself I found this NOS lantern. It came with a color matching propane bottle that is empty. My question is are these older bottles refillable like the modern ones?? I know the pros and cons of refilling a disposable tank so I’m not wanting to start a new debate on the subject but I would like to refill this one if possible. Thanks!!
Re: BernzOmatic profane ??
Pretty sure they are the exact same as new ones so yeah you can refill
Yeah Jason you can refill them just fine. Now you need the blue Bernz lantern 😉 it never ends 😁
sjsjr86s
Post by sjsjr86s »
just my 2¢; it's the soldering torch size, 14.1 oz canister. You could definitely refill it but if I were you i'd save that old bottle and use it only for display. Reason is the moisture and freezing you get from filling and using might damage the label or paint. I would instead get a refillable one from flame king on E-Bay and paint it with a rattle can to a similar color. then you can use and refill all you want and not worry about damaging the label/paint.
San Diego, CA
Thanks Levi, Toby and Steve!! That’s an excellent idea Steve. No sense in using this canister for anything other than displaying. Since it’s NOS I might not use it anyway but if I do I’ll use a new can. That tip was worth at least $.04. 😁
sjsjr86s
Post by sjsjr86s »
25_502s wrote: Wed Apr 07, 2021 11:57 pm Thanks Levi, Toby and Steve!! That’s an excellent idea Steve. No sense in using this canister for anything other than displaying. Since it’s NOS I might not use it anyway but if I do I’ll use a new can. That tip was worth at least $.04. 😁
careful now I may not be able to walk through a door again if you compliment my hacking prowess like that 🤣🤣🤣 keep us updated tho srsly! nice pull!
San Diego, CA
Wow. Finally one of my guesses is correct!
Leviticus_Tomethreus wrote: Thu Apr 08, 2021 12:07 am
You answer a lot of questions correct!!
25_502s wrote: Thu Apr 08, 2021 4:43 pm
All the easy ones. “Oh, well my 220J don’t light right. Easy F/A tube fix.”
pagrey
Post by pagrey »
You will easily get a good run out of that bottle without chilling it at all. Just hook it up and put a bit in. The only reason you chill the bottles is to get the bottle completely full. If you treat it like a normal lantern and just dump a bit of fuel into it you'll be able to enjoy it the way it is without the hassle of chilling the bottle, it's not like everybody tops up all their founts every time they run a lantern. To me a vintage lantern like that will look ridiculous with a home depot bottle, at least I don't think I'd enjoy running it that way.
Paul
Seen mine today 😁
So my other question is if the lantern is NOS and the fuel bottle came right out of the box why is it empty? Did it slowly leak out the last 50 years? Maybe the seller didn’t want to ship a full canister and drained it somehow?
sjsjr86s
Post by sjsjr86s »
Tgarner01 wrote: Thu Apr 08, 2021 5:51 pm Seen mine today 😁
we need a "like" button like on Facebook. here's mine.... 👍
San Diego, CA
