Evapo-rust mica before/after
I'm in no way affiliated with Evapo-rust and only doing this for our friend Chuck (Hot Diggity)
Rough mica in question:
Dropping in:
Soups on:
Good enough:
2 1/2 hours later:
Much better, perfect patina 👍:
New home:
Before & after collage:
Sold Chuck? 😁
Re: Evapo-rust mica before/after
Thanks Toby. That's much faster than I expected. I did a little reading on the Evapo Rust and they say the effectiveness depends on how much rust the solvent has absorbed.
I think it was 1/2 pound per gallon. They also report an unlimited shelf life.
It looks like somebody tried to blast a torch through the lifting tab hole without opening the lighting door on that one.
looks great. Ive been threating to get some.
I have had good results with citric acid as well. I got a little flash rust but I hope to clean that up with Naval Jelly and a Q tip
Good job on that. I'll have to remember that amount of time.
I'll never leave anything in Evaporust overnight again, unless perhaps I think the solution has gotten weak. I put an oil pot from a RR wickie in it once and when I took it out the next day, it had so many holes that it looked like it was made from screen. I know it's not supposed to do that, but I'll err on the side of caution going forward.
Hot_Diggity wrote: Wed Apr 21, 2021 8:47 pm Thanks Toby. That's much faster than I expected. I did a little reading on the Evapo Rust and they say the effectiveness depends on how much rust the solvent has absorbed.
You're welcome Chuck. I believe those hot spots you see are from holey mantles, couple spots in the mica as well.
mksmth wrote: Wed Apr 21, 2021 8:51 pm looks great. Ive been threating to get some.
Get a gallon or two to play with Mike. It has it's uses.
Rubing wrote: Wed Apr 21, 2021 9:27 pm I have had good results with citric acid as well. I got a little flash rust but I hope to clean that up with Naval Jelly and a Q tip
Yes citric is my go to for anything I'm not trying to save some original plating. This mica would've been a perfect candidate for it, but did Evapo-rust for Chuck 😁
JimL wrote: Wed Apr 21, 2021 9:33 pm Good job on that. I'll have to remember that amount of time.
Rusted holes? Or a reaction?
I dunno. It felt solid to me before it went in. I will still use Evaporust, but just not leave an item unattended for more than a few hours at a time without checking on it. I used Evaporust on this oil pot because it was supposed to be so harmless and replacement oil pots aren't cheap.
CoolPro
Post by CoolPro »
I'm sold on Evapo-rust as well - completely worth the price. I use it until I can barely see through it, than it's time to switch it up.
Cheers,
CoolPro - Kelly In Alberta
Novice Fettler
gwillmot
Post by gwillmot »
Been there, done that .... without heating it up. Just left it overnight and presto!
Still Crazy After All These Years
Mark 16:16
CoolPro wrote: Wed Apr 21, 2021 10:21 pm I'm sold on Evapo-rust as well - completely worth the price. I use it until I can barely see through it, than it's time to switch it up.
Cheers,
It's a miracle elixir for sure 😁
gwillmot wrote: Wed Apr 21, 2021 10:24 pm Been there, done that .... without heating it up. Just left it overnight and presto!
Works fine in the summer, in the winter it slows to a crawl in my experience... Just getting it good and warm with a lid on the pot really seems to speed the process up.
I can get a bucket up to temperature around here by just putting it a car at lunch time.
Willy
Post by Willy »
I've had good luck using vinegar. One note of caution is if the sliding door is made of zinc, vinegar will eat the zinc. The chimney in this case came off a Justrite lantern.
Willy
JimL wrote: Wed Apr 21, 2021 9:52 pm >>Rusted holes? Or a reaction?
I’m 99% sure it already had holes. It’s so common in those pots it’s not even funny. Half of my rr wickies have holes in the pots. They hold water.
The whole pot looked like it was made from a screen when I removed it from the Evaporust. It may have really been that bad, but did not appear that way when I started. I still use the stuff, depending on the project. As a result of the oil pot situation, I'm just cautious about leaving some items unattended in Evaporust for more than a few hours without checking on it. Hefty metal like lantern frames/cages, I'm not concerned.
Judamonster
Post by Judamonster »
I have forgotten unpainted things in evaporust for months without issue. Steel was dark but scrubbed clean.
paulbarrette
Post by paulbarrette »
Never thought of heating up evaporust. I left my mica in it overnight. That is a lot faster. Interesting post, toby.
Pb
Paul Barrette
Coleman Quick lite crew #52
Milspec Syndicate #00085
There is also another product like EvapoRust call Rust911. They sell it in concentration form for a price that is a lot cheaper than EvapoRust.
I've not done a side by side comparison. But I have tried it now on a couple projects and seems to work just like Evaporust.
If you buy the 16 oz concetrate it makes 2 gallons - about $15/gal. (a bit cheaper than EvapoRust at 16.5/gal)
If you buy 1 gal of the concentrate it makes 16 gallons. That's comes to 3.75/gal. (5 gal EvapoRust is about 16 gal).
And shipping is free.
p.s. i am not associate with this company - just letting folks know about an alternative to EvapoRust.
Buckeyecamper
Post by Buckeyecamper »
I have cleaned mica using evaporust before and I'm convinced. I recently picked up a couple of Coleman marked mica. Has anyone ever cleaned one of these in evaporust? I'm hesitant to as I really don't want to damage the Coleman lettering.
David A Jewell II
Boglo
Post by Boglo »
Buckeyecamper wrote: Sun May 09, 2021 8:32 pm I have cleaned mica using evaporust before and I'm convinced. I recently picked up a couple of Coleman marked mica. Has anyone ever cleaned one of these in evaporust? I'm hesitant to as I really don't want to damage the Coleman lettering.
I’d be cautious with the lettering. I did lose some lettering after a several hour soak. Kinda bummed.
Bo
