Any year SMP M1950 stove
425E
Post by 425E »
If you have a Smp any year model. what kind of problems have you had if any. all My smp M1950 stove will only turn from off to light and stop just 90 degrees from off position. Trying to get help from family to do picture post Any comment is greatly and highly appreciated. All comments welcome.
Re: Any year SMP M1950 stove
The knob should turn counterclockwise 180 degrees. - check to see if the handle is on correctly.
Here is a video which shows the direction and degrees.
TSPORT
Post by TSPORT »
That stove in the video looks mint!
425E
Post by 425E »
RE Phredd Do you mind emailing me if so don't do so
Sent u an email
425E
Post by 425E »
Thanks Phredd returned the same. Have a good one.
425E
Post by 425E »
I know that photos would help. So I'll try again to get help posting photos. From a family member or any local that i can get help from on the photo posting . Until then over and out 425E AKA john
John,
This probably won't help, but just in case something was made wrong...
The first pic shows the post over the valve used for the stops. The second pic is of the back side of the knob, which has the stops for full on and full off when they make contact with that vertical post on the stove.
Cajuncook1
Post by Cajuncook1 »
425E wrote: Fri Apr 30, 2021 3:04 am I know that photos would help. So I'll try again to get help posting photos. From a family member or any local that i can get help from on the photo posting . Until then over and out 425E AKA john
John, if you email me the photos, I will post them for you sir.
Look under the member name in this post. You will see the word contact. Click on the bubble just the right of contact and select the email option. Email me the pics and I will post them for you.
Cajuncook1
Cheers,
Cajuncook1
:cf_beercheers:
Cajuncook1
Better yet, I will PM you my email address. You have a PM 425E
Cheers,
Cajuncook1
:cf_beercheers:
425E
Post by 425E »
RE; Cajuncook1 Got your messages. They are very very much appreciated. Much gratitude to all who helped the photos did help. Double checked the knob is on correctly. Stove still hangs and stops at 90 degree light position. Will try to come up with photos in next few days again appreciate the help. 425E aka john
sometimes the excentric block gets bent or dirty with groves in em causing em to hang up . i file each side n nice n flat and deburr all the corners making sure i get a smooth movement before reassembly
here is yet another scenario , the excentric or generator gets stuck with carbon/debri and someone forces it anyways trying to clear it and it bends the end of the tip cleaner wire , the part that moves the excentric .... its takes some doing to see that like a good part next to it , i have been able to save a few by carefully bending the wire back into position , its not much of a bend to correct it , some trial and error till it gets better at rotating ... its always a case by case fix , im just giving you a couple areas to look at .
sounds like a likely senario. I had one that would not move at all because it was twisted and jamned…
