Got this in the mail
10gage
Post by 10gage »
Can someone tell me the proper clocking? Also it came with this mica chimney, but didn’t it have the other style with the round lighting door and full metal panel?
James gage sizemore
milspec syndicate #1941
slant savers #68
quicklite crew#43
Re: Got this in the mail
Not sure of the clocking but that looks like it will clean up good. That mica looks like the ones I have.
Bouncing between California and Washington....
James on those Air-O's I've found the fillers are normally clocked 90 degrees to the valves left or right. Then on the later 327s it seems they went to 180 from the valve... Not sure anything is set in stone on those.
As far as mica you need the tall narrow reflector with the lighting hole. Scroll down in this post to see Larry's photo.
viewtopic.php?f=5&t=28471
10gage
Post by 10gage »
Tgarner01 wrote: Sun Nov 07, 2021 5:22 pm James on those Air-O's I've found the fillers are normally clocked 90 degrees to the valves left or right. Then on the later 327s it seems they went to 180 from the valve... Not sure anything is set in stone on those.
That’s what I was wondering. The valve was opposite of the filler but who knows. It seems that the mica was probably replaced with this one I’ll see how well it cleans up and I’ll probably get Fred to make a proper one. I’m cleaning it now and can barely make out the airo lantern and model ql. Thanks
James gage sizemore
slant savers #68
quicklite crew#43
AFIK, the base plate half-moon cut-out over the filler; the air tube over the hole on the base plate and the valve centered vertically in the collar is about it.
10gage wrote: Sun Nov 07, 2021 5:39 pm
Clocking is a big pet peeve of mine, but when I see a 327 clocked 90 or 180 I'm fine with it 😁
It will need clocked 1 hour back today: :mrgreen:
10gage
Post by 10gage »
After receiving a replacement frame collar from a generous member here. She lives again for another 100+ years. The collar on this one had nearly 50 percent of the bottom gone.
James gage sizemore
slant savers #68
quicklite crew#43
Awesome!!
Beautiful!
wow. You got that one looking really nice.
10gage
Post by 10gage »
Thanks everyone I will say these old ones are what I enjoy most about this hobby. I cleaned up the mica a bit for this pic
James gage sizemore
slant savers #68
quicklite crew#43
Nice work, James, and I agree that these old ones are wonderful lanterns.
Lookin' GRRRREAT!
I love the gentle hissss of the old Quikies.
Great job, and the mica looks exceptional! I've yet to find one worth saving.
Money!! Excellent job bringing it back to life, James. That turned out to be a real good looker.
10gage
Post by 10gage »
Gunhippie wrote: Sat Nov 13, 2021 4:01 am Lookin' GRRRREAT!
It’s not without its flaws, however not worth redoing. I’m about 50/50 on being able to use a original if I find one. Need to have some made and repaired
James gage sizemore
slant savers #68
quicklite crew#43
