Pump Cup - inside out or outside in
I think this has been discussed in the past, but i could not find the thread...
I've bought new leather pump cups from a couple different sources in the past. And some come with skin side out (the side that faces the pump tube) and some come the the rough flesh side out. Seems to me that the former should be better since the flesh side is always rough and bits and pieces can come off easier.
What says the CCF collective wisdom?
Kevin#2
Re: Pump Cup - inside out or outside in
If easy enough to fold it to choose, I'd go with the smooth side out. I'm basing this on occasionally seeing what appear to be leather bits at the bottom of the pump tube and believe this is the cause of some check valves getting stuck.
Original and current production Coleman leather cups are rough side out to the pump tube.
My experience with smooth side out pump cups is not good.
Rough side soaks up oil better than smooth.
Some repro pump cups are bad in that neither side takes up oil even after 10 days soaking.
Good question, I've always wondered why most (not all) are rough side out. Personally I have made em both ways and both work.
bp4willi
Post by bp4willi »
Interesting thoughts.
brass bender
Don't seem to matter. Ever NOS Colemans seem to go either way.
Now, leather boots? Smooth out. Rough out gathers too much dust and sand and wears much faster. But I won't be taking any of my pump cups for a run in the mountains.
So looks like the wisdom of the crowd is you can do it however you want. Freedom for leather cup users!
Kevin#2
Phredd wrote: Thu Nov 18, 2021 2:07 pm So looks like the wisdom of the crowd is you can do it however you want. Freedom for leather cup users!
Fred
There are smooth pump cups out there that don’t work well until turned inside out.
It may be more an issue with how they got them to maintain shape. The smooth side doesn’t suck up oil even over night. They are awful hard right out of the gate.
Northern hemisphere - rough side out
Southern hemisphere - smooth side out
Why? Coriolis Effect
Kevin#2
REJ2
Post by REJ2 »
Rough side out for me, that’s what I buy and that’s what I make when I’m making them
Whitegas Extraordinaire wrote: Wed Nov 17, 2021 8:57 am Original and current production Coleman leather cups are rough side out to the pump tube.
What Kevin said.
I make my own mostly and the smooth side out is not what you want.
