288 o-ring
288 o-ring
Post by ecblanks »
Trying to diagnose why my 288 is flooding so badly on lightup (yes I'm aware that they "do that" , but mine is worse than it should be), and noticed this o-ring part from OCP.
Is it the same as the black rubber o-ring at the top of the F/A tube? If so , why does it look brass in this pic?
Carlton
ICCC Member #1892 (expired)
Re: 288 o-ring
Yea, Carlton, that is same the o-ring that is on top of the fuel feed tube. Not sure on the color difference, I think (?) the one I purchased from OCP earlier this year was black.
If your lantern is flooding, have you made sure the air passageway in the fuel feed tube is clear? If the tube is compromised--restricted air circuit or cracked below the fuel level line--it will only grab straight fuel.
I'm assuming the fount is not overfilled? Do you have another tube to try in its place?
Re: 288 o-ring
"Trying to diagnose why my 288 is flooding so badly on lightup (yes I'm aware that they "do that" , but mine is worse than it should be)"
What is your startup procedure? If this is an "adjustable" lantern, the fuel control valve needs to be put full open for starting up.
Re: 288 o-ring
Post by ecblanks »
Just tried it out; the air passage is completely blocked. I had bought the tube from OCP about 3 years ago, so I compared it to my original tube. I swapped the cores and rings (the ring on the old tube crumbled; probably what was wrong with it), so now I should have a good one. Should be testing shortly.
Carlton
Re: 288 o-ring
Post by ecblanks »
That took care of it. There's not much left of the o-ring that's on there so I may still end up getting a couple.
Carlton
Re: 288 o-ring
Good news! Glad to hear it was a relatively quick fix.
A fresh o-ring will definetly keep any air from seeping past those threads causing a slow depressurization. You can check it now if you want to by pumping up the empty fount and dipping the genny tip into some water while the fuel valve is off.
Re: 288 o-ring
Post by ecblanks »
Ridge Runner wrote: Fri Nov 19, 2021 6:10 pm Good news! Glad to hear it was a relatively quick fix.
I have way too much stupid optimism to do an incremental test. Already put it back together and lit it, twice! Yeah, this has bitten me more than once :D
Carlton
