Jet A
Fortech1977
Jet A
Post by Fortech1977 »
Has anyone ever burned Jet A1 in their kerosene appliances? Curious as I have stumbled upon a few gallons.
Thanks in advance
- Brian
British Columbia, Canada
Re: Jet A1
Lots of guys have just don't burn it indoors if it has prist in it
Re: Jet A1
Short answer, yes. Its a desirable commodity for those that burn a lot of kero gpa.
Re: Jet A1
It doesn't necessarily have Prist or another brand of de-icer in it. One needs to ask from the source of the fuel. Some smaller airports would more likely purchase jet fuel with it already added whereas larger facilities are more inclined to add it when refueling. If you don't know, I suggest you don't burn it anywhere near you. I was offered all I wanted, but it had the de-icer in it, so I only got one gallon and burned it in a wickie a distance away. Supposedly all brands of the de-icer's fumes are considered toxic. I'm not going to find out the hard way.
I've only burned jet fuel in my kero GPA's, except when I've run out and then used CF in kero GPA lanterns.
Re: Jet A1
I've used a couple of gallons of it in my 639C.
Old Cat
Re: Jet A1
Post by Old Cat »
Thanks for sharing your thoughts on JetA. I have a small airport nearby and thought I would look into purchasing a gal. I wasn’t aware of the additives. Now, I know what to ask.
sleebus
Re: Jet A1
Post by sleebus »
Fortech1977 wrote: Mon Sep 19, 2022 2:25 am Has anyone ever burned Jet A1 in their kerosene appliances? Curious as I have stumbled upon a few gallons.
Thanks in advance
Just so you don't look odd when going to the airport, it's Jet A, not Jet A 1, that doesn't exist.
Michael - ICCC#2163
Check out my channel at GasUnderPressure or chat on the Coleman Discord
Fortech1977
Re: Jet A1
sleebus wrote: Mon Sep 19, 2022 3:34 pm
Thanks in advance
Correct! We have some heli activities at work and the tank is labelled "Jet A with FS II", which my Googlefu indicates means the de-icing agent is present.
- Brian
