Inverted disassembly/reassembly...updated with instructions and pics
Thought I would pose this question. Tonight I will be tearing apart my Kamplite inverted (for about the 3rd time this week) and putting it back together. Would it make sense for me to take some pics and describe the process? I checked and didn't see the instructions posted anywhere but thought I'd check to see if anyone would find them valuable. If so, I can snap some pics and type up a few instructions when I take it apart and reassemble it. Let me know if there is interest.
Lanterns are like cats....if you have more than 3 in the house, people start to think you are a little weird.
Ok here we go. I'm sure I'll leave out some important details but if there is anything you have questions on, let me know.
Here is our victim, I mean lantern:
Of course, with these, the first step you want to take is to remove the globe, globe ring and reflector. The globes are very hard to find so put it somewhere safe. Once you remove those pieces, turn the lantern upside down. It should look like this (hopefully yours is less sooty than mine):
Note the 3 threaded studs sticking up around the burner. Those studs are what you want to work on next. The studs are threaded on both ends. One end is what you thread your globe nut onto. The other end threads up into posts that extend down from the fount. You may be able to turn the stud with just your fingers or you may need to get a pair of pliers (with some leather of course to protect the metal) and turn them with that. Regardless, they should come out fairly easily. Once you remove those studs, be careful when you are moving the lantern around as all that is holding it together now is a very thin copper fuel line. You don't want to kink or break that fuel line. Carefully lay the lantern on its side. Note the vented "collar" that circles the lantern below the fount:
The next step here is to remove the two screws that hold that collar on the lantern. Take out the 1st screw. NOTE: With the 2nd screw, be CAREFUL when you remove it. The collar will have some "spring" to it and when you get that 2nd screw loose, if you aren't careful, it will launch the screw into the recesses of your workbench never to be seen again. There isn't a lot of spring there, but enough to launch a very small, very hard to replace screw. Be careful as you remove the collar. There are 2 things you need to watch for. First, the collar is held together by one very small strip of metal right where the control valve sticks out. It would be very easy to kink, bend or break that small strip so be gentle. Second, when you remove the collar, there are 3 rubber "grommets" that were held in place by the studs you removed in the first step. Those grommets are now loose inside the space between the lower part of the lantern and the fount. When you remove the collar, those rubber grommets will be free to roam and if you aren't careful to watch for them, they will join your collar screw in hiding. The other piece that is loose is a small 3 sided "box" with a screen on it. This assembly serves to cover the air intake tube and I would guess the screen is to prevent any large items such as june-bugs, etc from entering the air tube. Note the orientation of this box as it is tapered. The narrower end of the box should be in against the chimney if I'm not mistaken.
Once you remove the collar and gather the grommets into a safe place, you'll see that there is a fuel line that goes from the fount to the burner. This fuel line (as mentioned above) is now the only thing holding the lantern together and as you can imagine, it creates a very delicate situation. Carefully remove the nut connecting the fuel line to the bottom of the lantern. Here is a pic of that assembly:
Once you remove that nut, the lantern is now ready to be separated into 2 pieces.
Next, you are going to focus on the valve. Remove the other nut holding the fuel line on the valve. NOTE: I would try to set the fuel line somewhere with the same orientation it had when you removed it from the valve. Both ends of the fuel line have the same size fitting but the fuel line needs to match up with the valve on the fount and the line feeding the burner on the bottom half of the lantern. Keeping this fuel line "oriented" to the way it came off the lantern makes life much easier. Otherwise you will be trying to figure out which end is which. I guess the other option would be to put a small mark with a marker on one end so you know which end goes on the valve body and which goes to the burner. Whatever works best for you, just find a way to remember; it will make things much easier in reassembly. Also pull the valve wheel off as the valve will not spin out of the fount with the wheel in place. It will hit one of the "posts" coming out of the bottom of the fount if you don't remove it.
Once you get the fuel line off, you are ready to remove the valve from the fount. I personally like using a wrench and a screwdriver as pictured below, but use whatever method suits you. NOTE: Take note of the position of the valve BEFORE you start to turn it. When putting the lantern back together, you will need to line the valve back up in nearly the exact same spot so that the fuel line lines up with the burner connection. I would recommend you put a piece of masking tape on the fount and put a line on it so that when you reassemble, you can line the valve up with that mark. Also note that the valve has 2 different sized ends. It probably goes without saying but when you put the valve back in the fount during reassembly, the larger end of the valve will need to point out to accept the valve wheel assembly.
Once you loosen the valve, it will look like this:
The valve has an "F/A" tube of sorts connected to it. That F/A tube is removable and you shouldn't need anything but your fingers to unscrew it from the valve body. If you do need to use a tool, I would be very careful not to crush or bend the tube. It is a hollow tube and won't stand much compression. Once you remove the F/A tube, you will have 2 pieces like this:
Note on the end of the F/A tube closest to you in the picture there is a very small screen. Do not lose this screen. It should slide off the end of the F/A tube opposite the end with the threads on it. DO NOT try to slide it over the F/A tube threads or you risk ripping the screen, etc. Once you remove the screen, note the very, very small orifice in the F/A tube. You'll have to look hard for it, but it is there. Many times, if your fount has any gunk in it, it will end up here. Odds are good that your screen and this orifice are plugged and I would recommend you clean them with carb cleaner and some compressed air (carefully).
If you want to remove the "chimney" from the center of the fount, you can easily do that. There are two screws on the top of the chimney. Loosen those screws and you will be able to lift the entire chimney assembly up out of the fount. BE CAREFUL as there are some small spacers on the screws that may want to join the grommets and the collar screws in hiding so as you lift the chimney, watch those spacers to make sure they don't drop off the long screws. Additionally, the bail handle is easy to remove if you choose to do so. Just pull each side of it away from the fount and the ends should come out of their holders just like on a regular Coleman vent.
In terms of cleaning, now is the time to do it. I would spend extra time on a BB shake for the fount and rinse and rinse and rinse. With the inverted lantern, your fount can never be too clean given the small screen and orifice assembly. Any flakes, gunk or
otherwise in the fount will get sucked into the orifice and you will be reading these instructions again as you pull the lantern apart again. I would run compressed air through the fuel line, burner, etc. The check valve on these is not removable so just remove the pump and treat the leather cup as you normally would and give the CV a shot of carb cleaner if you want for good measure. The fuel cap is a 3 piece cap and you can replace that with a standard 200/220/228 size gasket.
Ok. Now to reassembly. Your first step is to put the cleaned screen back on the cleaned F/A tube (carefully). Now, screw the threaded end of the F/A tube back into the valve body. Once you have that back in, you are ready to put the valve body back into the fount. Drop it in and finger tighten it. Use your box end wrench and screwdriver to tighten it and line it back up to the mark on the piece of tape you put on the fount.
Once you have the valve in the right position, put your fuel line back on the valve with the correct orientation so it lines up with the burner tube fitting. This orientation is important so look at it twice before you tighten the fitting of the fuel line on the valve body.
Once you have the fuel line oriented about where you want it, tighten the fuel line nut on the valve body. You have to do it now because once you mate the two parts of the lantern together (top and bottom) you won't be able to reach that nut with a wrench. Once you've got the fuel line tight on the valve body, you are ready to mate the upper and lower parts of the lantern back together.
I find this is most easily completed by laying the lantern on its side. These next steps are the most difficult of the process but they aren't that hard provided you have everything lined up correctly. First step is to connect the loose end of the fuel line to the bottom half of the lantern. Now you'll need both hands. You will be replacing the threaded posts we talked about earlier. To replace these posts into the lantern, start by pushing one of the posts up through the hole in the bottom half of the lantern. It will then need to have a rubber grommet put on it and be threaded into the post coming down from the fount. The holes should all line up if you reassembled your fuel line and valve with the correct orientation. Here is a pic of the grommet in place:
Get those threaded posts started but don't tighten them yet. Once you have all 3 of them started, you will need to get the screen box back in place between the fount and the lower part of the lantern. Here's a pic of it slid in about half way to where it needs to go. Note the opening on the lower part of the lantern. It is a hard to see "circle" between the box and the chimney in this picture. This is what it needs to cover as it is the air intake opening:
Once you have that box in place you can tighten your threaded posts the rest of the way. Finger tight is just fine. Now, replace the valve wheel into the valve body. If you removed the chimney, replace that as well. Note that the inner ring of the chimney should fit over the raised rim of the lower half of the lantern. This connection directs the heat from the burner up through the hole in the fount and out the chimney. If you don't have this seated properly, you risk having too much heat under the fount and that is not a good thing. Once you do that, you are ready to test the lantern. I would recommend you test the lantern before you replace the vented "collar". Put some fuel in the fount and give it some pumps. Of course you'll need to have a mantel on the lantern ready to go. Give the tip cleaner a couple of spins and crack your valve. Assuming the lantern is burning well, before you replace the reflector collar and the globe, make sure there are NO HOLES in the mantel. Again, these globes are very hard to find and you don't want to have a mantel hole result in a scorched globe or worse yet, a cracked globe. Also, when shutting down the lantern, I would recommend using the tip cleaner to shut it down to avoid the "pop" these lanterns are known for. That "pop" can cause a hole to form in the mantel.
Assuming the lantern is burning well, you can now replace the vented collar. Again, be careful of the portion of the collar that goes over the valve. This is a very thin piece and would be easy to break or bend. Compress the collar around the body of the lantern and get the screws back in. This will be at least a 2 hand operation. Now your lantern should be good to go for use.
Hopefully these directions help you and use them at your own risk. I'm no expert but this process has worked well for me.
