I start with a 3/4" copper pipe cap
And some 5/16", .014" wall brass tubing
A 5/16" drill bit...........
......and our cap chucked up in the vise, gives us a hole that will take the brass tubing, AND allow us to insert a 5/16" bolt onto which we will thread a nut.
Now we have a way to turn the cap in our tubing cutter. I aim for somewhere around a 1/2" to 5/8" deep cup. Sometimes the piece seems to walk in the cutter so it's never an exact science for me.
Now I'll take my tubing and using a tubing flare set make a single flare
Now I'll just gauge my cup and mark where to cut my tubing.
This is a tight enough fit that a gentle tap from a hammer may be needed to seat the brass into the copper.
And I'll usually pound the metal flush for a good tight fit
Solder, cup, and torch...........
Make sure to heat primarily the copper. The brass is super thin and will get hot all by itself.
A little dressing with a couple of files
Flattened the bottom out nicely.......
And it fits perfectly over a 200a generator.
