Coleman Fuel Cans Updated!! Post #5 7/10/14
A fellow member of the ICCC has done some research and has allowed me to share that information with the members of the Forum. The research material was from Coleman catalogs showing cans of Coleman fuel. Here is the information and I want to thank Ron Becker for sharing it with us.
If anyone has a collection of Coleman fuel cans, we could add pictures to the related years in the descriptions from Ron's research.
Here is the information:
US Coleman Fuel Cans
1954, 1955 - ? - Flames on can with Stove and Lantern. - 1 gal. or 1 quart
1959 - 1962 - Only 1 flame on can with Stove and Lantern. - 1 gal. or 1 quart
1963 – only - Only 1 flame on can with Stove and Lantern, Especially Blended. - 1 gal. or 1 quart
1964 - 1965 - No Flames on can, just Stove and Lantern - 1 gal. or 1 quart
1966 - 1967 - Stove, Lantern, and Catalytic Heater. No size amount on can. - 1 gal. or 1 quart
1968 - 1973 - Stove, Lantern, and Catalytic Heater. Has size amount on can. - 1 gal. or 1 quart
1974 - 1975 - Stove, Lantern, and Catalytic Heater. Has size amount on can and white plastic cap. - 1 gal. or 1 quart
1976 - only - Stove, Lantern, and Catalytic Heater. Has size amount on can and white plastic cap. - 1 gal.
1977 - 1978 - Stove, Lantern, and Catalytic Heater. Size amount on can. Has red plastic cap. Says on can Fuel for Gasoline Camping Appliances. - 1 gal. only
1979 - 1983 - Stove, Lantern, and Catalytic Heater. Size amount on can. Has white plastic cap. Says on can Fuel for Gasoline Camping Appliances. - 1 gal. only
This information will be moved to the Tech Assist Archive in a few days.
9/4 Edit! 1963 added
StanDahl
Post by StanDahl »
This should help to illustrate Ron's findings. This post was modified much later than the others on this topic, so it may make earlier posts below seem redundant or not make complete sense:
1956 - 1957? (Ads and catalog)
This style first appears in 1956 magazine ads and runs until at least 1957. I have no data whatsoever for 1958, so I can’t verify when this one ends and the next one begins. There is also one with the dual cap/pour spout somewhere in this date range (below - photo by KellyBlues.
[above] 1959? - 1962 (Catalogs and ads)
As far as I can tell, this style first appears in 1959 Outing catalog. It may have come out a year earlier, but I have no proof. It was used until at least 1962 (Coleman Outing Catalog).
[above and below - front and back] 1963
I have no record (catalogs or ads) of this style at all, it seems to me to be a “transition” between the last and the next, so I’m declaring it to be a 1963 only version. The other side of the can is similar to the one above, but not identical. If only I could find a 1963 catalog...
[above] 1964-66 (reference: Coleman catalogs)
There may be minor variations in text arrangement on some of these and the next versions.
[above] 1967-68 (reference: Coleman catalogs)
The heater seems to have been added in 1967, at least according to the catalog. There may be minor variations in text arrangement on some of these. (I don’t have a 1 gallon example of this one yet, but you can see one in OldSoul's post #13 below.)
[above] 1969-73 (reference: Coleman catalogs)
The fixed price no longer showed in the catalog in 1969. There may be minor variations in text arrangement on some of these and the next version. (The one on the left is the one Warren referenced as NOS in the post below this - it's still full!)
[above] In 1974-76, the cap has a white plastic safety wrap, but otherwise seems the same. (Catalog photo)
[above] 1978- (reference: Coleman catalogs)
The cap is a twist and pop type. Note new heater style and silver warning background. (No 1977 catalog available)
[above] 1979 - 82 (reference: Coleman catalogs - catalog photo)
The cap is again the white plastic safety type. Note white warning background. (There are no fuel cans in the 1983 catalog, and I only have one catalog beyond 1983 available)
[above] Unknown date - I suspect it could be just after the one above it, but have no catalogs to compare to. It does have what is probably a 220K, which ended in 1983. The cap is a red plastic safety type.
[above] Mid 1980’s - 1990’s
I have seen this style can in a 1986 Coleman camping video and in the 1990 Coleman catalog. I don’t know anything more.
Here's a newer one, there is a code on the bottom, when compared to the code on new cans makes me think 1992:
1990’s - 2000’s?
The can above is English-only and so is probably older than the one below with multiple languages.
I don’t know the dates on these at all. Maybe some of you have some idea of when they came out?
warren
Post by warren »
It would be great to have a picture reference for all of these.
Add to this the Citronella added fuel cans. I think Greg got mine. Maybe he can post a picture. (quart size)
Also I have a made in England can. Greg I think it is in the box of stuff you have if you can find it. I don't think I sold it. (quart size, but probably metric)
It shouldn't be too hard to get all this lined out. Let's save the off brand cans for another post.
John if I had a way to get it to you, I have an NOS red fuel can like that. Still have the metal plug under the cap sealing the spout. (I have 2, unless I gave one to Greg or Steve.)
The modern (2000yr+) cans have changed over time also.
If you don't here back on a PM, try to EMAIL me.
ANTIQUESWV on Ebay
#1 in the 223B club
Gatlinburg, TN
StanDahl
Post by StanDahl »
Warren, I would like to get one of those! [I guess I do have a 1qt example of that version, but a 1gal would be nice.]
I have a few more. There were a number of variations of the red cans, including the type of catalytic heater shown and those with the white price label being filled in or left blank. Kellyblues has a version of the 1qt can on the bottom left with the same price but a different layout, similar to the one at the bottom right. There are lots of variations of the bottom lines too.
JimDouglasJr
Post by JimDouglasJr »
NICE INFO! I have several different cans. All part of the story.
Scouterjan
Post by Scouterjan »
Murff, thank you for starting this thread.I agree Warren, a picture of each can would be great. I have a different Canadian 1, I think, but will have to check and post a picture
lamplighter44
Colmanaholic
Post by lamplighter44 »
This is just another way you guys are influencing me.. I'm primarily a user of Coleman GPAs, not a collector. Over the last year there have been some fuel can pictures. I thought that was dumb.. Now, I must admit, I've found a place to put some of the oldies I just happened to have around. Nothing impressive. I'll show you when I can. My better camera has died and my phone camera needs better light than I have at this time of day.
Lamplighter44
Richard
I can't believe I'm gazing at other men's cans...
South Eastern Pennsylvania
MustXcape
Colmanaholic
Post by MustXcape »
I support putting these in a chronological post for easy reference.
So what's the story with these? (images swiped from the 'net). I assume they are all European. (my that clear plastic bottle looks flimsy...)
I can stop collecting anytime. I just don't want to.... Soooo.... How much do you want for that?
[75x48200a1][75x4840][75x4810][75x4820][75x4860][75x4890][75x4830]
OldSoul59
Post by OldSoul59 »
Here's my best two. The qt. was found inside a really nice three leg slot 413E. The gallon all by itself at a garage sale where the owner informed me, "oh, I sold the lanterns last weekend". ;-(
Wife: "Whataya gonna do with all those stoves"
Coleman 275 A S member # 0029
Looking For US Made 11/59 Lantern
Don
Duster08
Post by Duster08 »
I need s canadian fuel cannto display with my 321s
Jason williams All around collector
GasPrescue
Post by GasPrescue »
Here is the Citronella quart sized
[ColemanCitronellafuelcan_zps41447452]
Scouterjan
here is another Can can, shape is way different than the 1 st 1 I posted
LP
Post by LP »
Here is an oldie I picked up this summer! [smile]
One must always take the high road - all other roads are dead ends.
LP
ICCC Member #846
RustyBus
Post by RustyBus »
I almost didn't post mine after I saw Oldsoul's $1.59 can, but a quick look shows they're quite different. So here's my $1.59 gallon o' CF:
DSC_8024
Brooks
Coleman 275 Appreciation Syndicate #0153
