502 stove
502 stove
Is there a trick to getting the F/A tube out of a 502 stove? I tried putting the tee in a vice and could not budge it. It looks like there may be so loctite on the threads. I have the stove completely apart except the check valve & the F/A tube.
Jeremy
Jeremy
- Scouterjan
502 stove
Jeremy, I tried everything and am not sure what they used to seal the threads.In the end I used a heat gun, like a hair drier, to get the valve area really hot, clamped the font in a vice upside down, then used a strap wrench, thanks Quest, around the bottom of the font and finally broke the valve free. Hope this helps
- kellyblues
- Senior Member
502 stove
A big 9 outside here in Indiana
I have a fount vice and a valve tool. With those I can break the red locktite on the threads but I sometimes have to use a cheater on the valve tool. These are a bear.
Kelly
Kelly
Just trying to thread something together or lite something on fire. KW
ICCC member # 1154
ICCC member # 1154
- Murff
- Administrator
- Title: Guy Who Knows Just Enough To Cause Trouble
502 stove
The "C" stands for "Canadian", eh?
Murff----->
Name: Murff ICCC Member #726
Coleman Blue's 243's #002 Ebay Handle: Happy-campers2
- Scouterjan
502 stove
Global warming or climate change, call it what you will. Here on the west coast of Canada all kinds of temp records are being broken and to have a white Christmas is quite the exception. What the hell do Lab Rats know?
