502 stove
rainjer
502 stove
Post by rainjer »
Is there a trick to getting the F/A tube out of a 502 stove? I tried putting the tee in a vice and could not budge it. It looks like there may be so loctite on the threads. I have the stove completely apart except the check valve & the F/A tube.
Jeremy
Scouterjan
502 stove
Post by Scouterjan »
Jeremy, I tried everything and am not sure what they used to seal the threads.In the end I used a heat gun, like a hair drier, to get the valve area really hot, clamped the font in a vice upside down, then used a strap wrench, thanks Quest, around the bottom of the font and finally broke the valve free. Hope this helps
rainjer
502 stove
Post by rainjer »
I ended up using a torch and carefully heating up the thread area. That is all it took. The F/A tube is green. I will soak it and see if that helps.
Jeremy
Don_b
502 stove
Post by Don_b »
If all else fails put in in a freezer over night
rainjer
502 stove
Post by rainjer »
It is only 20 at my house.... The last piece I need to get out is the check valve. It is leaking.
BCosby
502 stove
Post by BCosby »
Just checked KC is a balmy 2.
-Looking for any 6/67-
kellyblues
502 stove
Post by kellyblues »
A big 9 outside here in Indiana
I have a fount vice and a valve tool. With those I can break the red locktite on the threads but I sometimes have to use a cheater on the valve tool. These are a bear.
Kelly
Just trying to thread something together or lite something on fire.    KW
ICCC member # 1154
502 stove
The "C" stands for "Canadian", eh?
Murff----->
P.S.
Scouterjan
502 stove
Global warming or climate change, call it what you will. Here on the west coast of Canada all kinds of temp records are being broken and to have a white Christmas is quite the exception. What the hell do Lab Rats know?
