Epay 200A resurrection
A Seabee
Post by A Seabee »
I was jonesing for a 200A, so I bought this little red wonder, 1 59, my first. Probably payed too much, but it wasn't a fortune either. It hadn't run in God knows how long, but was complete. cleaned the varnish out with BBs and a mix of fuel, WD40, and Berrymans, washed her up a bit, cleaned the fuel air tube, stretched the spring. removed and cleaned the check valve, cleaned and oiled the leather. It's a bit hard to pump. does the pressure pipe ever get plugged?
Re: Epay 200A resurrection
There's a snorkle attached at the base of the pump tube that opens near the top of the fount. The air you pump into the fount passes through this snorkle, and yes, it can get plugged. I had a plugged snorkle on a 400B stove. Soaked it overnight in denatured alcohol, and I was able to force the plug out the next morning just by pushing hard on the pump.
Stewart
A Seabee
Post by A Seabee »
TwoCanoes wrote: Tue May 04, 2021 4:44 am There's a snorkle attached at the base of the pump tube that opens near the top of the fount. The air you pump into the fount passes through this snorkle, and yes, it can get plugged. I had a plugged snorkle on a 400B stove. Soaked it overnight in denatured alcohol, and I was able to force the plug out the next morning just by pushing hard on the pump.
Thank you. If it doesn't get better on it's own I may give that a try. you just fill the fount with the alcohol?
Bumpkin_95
Post by Bumpkin_95 »
Looks good. Try the alcohol or some carb cleaner in the pump barrel. Give it 1 pump to force it past the check valve and in to the snorkel then let it sit over night and try it the next day. Good luck and nice lantern.
My other personality’s call me Lee
Milspec Syndicate member #1995
Lick a lantern just hanging out
Iccc member #1927
kellyblues
Post by kellyblues »
A Seabee wrote: Tue May 04, 2021 4:53 am
Do not fill it with alcohol. If it has the factory sealant on the floor of the fount alcohol will cause it to peel up. I usually put some cfuel in the pump tube and push it in the snorkel and let it sit. That and time usually takes car of it. I just did this on a 249. Literally started getting better the next day.
Milspec syndicate #0044
ICCC member # 1154
Looking nice and burning bright! You got that one looking good for a 62 year old lantern.
That is a nice 200A! Looks nice and bright!
kellyblues wrote: Tue May 04, 2021 10:16 am Do not fill it with alcohol. If it has the factory sealant on the floor of the fount alcohol will cause it to peel up. I usually put some cfuel in the pump tube and push it in the snorkel and let it sit. That and time usually takes car of it. I just did this on a 249. Literally started getting better the next day.
Thanks for catching that, kellyblues. The stove I cleared with alcohol didn't have the fount lining, and, correct me if I'm wrong, but 200As from 1959 didn't, either. But you're right - I have used alcohol to try to remove the lining on lanterns in which the lining has started to blister. As Bumpkin_95 suggests, carb cleaner might be a good alternative too, but be sure not to get the carb cleaner on the fount's paint. It's a great paint remover.
Stewart
kellyblues
TwoCanoes wrote: Tue May 04, 2021 2:27 pm
I don't remember the exact years tbh. I just make it a habit to never use it. Another method I use if the snorkel is clogged. Remove everything above the valve assembly, remove check valve, fill 3/4 with Coleman fuel, pump a few times , place it upside down in a metal pot or bucket and leave in the direct sun light. The clog is normally closer to the pump since it's the oil from the pump and leather fragments that clog it most of the time.
Another way is using a hydraulic slammer. I believe Mike sells them. I made myself one years ago. It's slightly smaller than the pump tube. Put fluid in the pump tube, insert tool and whack with a hammer. This works very well. The only thing I don't like about it is it pushes the gunk into the fount.
ICCC member # 1154
A Seabee
Post by A Seabee »
I think I’ll try the alcohol or cf in the pump tube first and see what happens. I went out this morning before work and pumping it up seemed a little easier with just having used it last night.
But, any way that the clog is cleared is going to dump into the fount, right? And will a little alcohol in the fount with the fuel cause any problems? Or should I dump that tank and rinse again after the snorkel clears?
Post by Dmacp »
fill the fount with boiling water, cap it and invert it. The heat will melt the congealed pump lube in the "snorkel" and you can clear it with the pump.
To remove sludge and rust, I use boiling citric. In this case, plain boiling water may work fine. However, one difference from Dan's suggestion that I would use is to fill with boiling water, tip the lantern so the boiling water gets into the snorkel, then leave it sitting right side up. Although both methods would likely work.
Just make certain there's no pressure in the fount with the boiling water. The check valve does a great job of holding back the air, not so with liquid. If there's pressure and you open the pump, any liquid in the snorkel and check valve may squirt out at you.
It's 1/'59. No fount liner.
I use carb cleaner for this. It's much better at dissolving the varnish, as that's what it was formulated for. Just don't get any on the paint. Carb cleaner will also burn just fine, so a partial pump tube full isn't a problem--no need to drain fuel.
A Seabee
Post by A Seabee »
Gunhippie said-
What happens to the substance that is blocking the snorkel? I thought I had this one figured out, but it seems plugged worse than ever now. When I unscrew and press the pump, it's nearly impossible to push. I can push the pump, but it feels almost like the stem is closed, but it's not. 20 HARD pumps and barely a whisper from the fount when I open the fuel cap. If I just pump it once, slowly, I can hear the air bypassing somewhere, probably at the pump itself. There is no leak on the fount, I'm positive of that
I have not tried putting anything in the pump tube, but I'm gonna try this morning. just want to make sure I'm doing it right.
take the pump out
pour in the plug dissolving liquid of my choosing-denatured alcohol or carb cleaner
put pump back in (screws too?)
pump? liquid in the pump tube want's to come back out
let it sit
do this until plug clears?
A Seabee
Post by A Seabee »
Also, I have isopropal alcohol, 99%, will that not burn with the fuel? or must I use denatured?
A Seabee
Post by A Seabee »
and, if I fill it with boiling water, should I take out the check valve? leave the fuel pickup and valve in place?
You shouldn't need to remove anything, but if you'll have gunk floating around in the fount, you might be better off removing the F/A tube. That is, if you've already cleaned it. Just remember that boiling water will heat whatever air is in there and with the pump out, you may get a spray out of the pump when the gunk gives. Coleman check valves are great for stopping air, but not liquids.
