Saved a 237 this weekend
Emorr123
Post by Emorr123 »
Anyone need a Zebco globe?!
Eric
MilspecOps #1272
Coleman Quick Lite Crew #7
ICCC #1789
Re: Saved a 237 this weekend
Wow Eric! Hope the fount is okay... Nice save!
thezman
Post by thezman »
Yikes, that bottom looks sketchy.
I'm Larry most of the time.
I agree the bottom of the fount looks really scary.
paulbarrette
Post by paulbarrette »
That will be interesting to see how it survives de rusting. What is your plan, evaporust? Looks like an interesting project.
Pb
Paul Barrette
Coleman Quick lite crew #52
Milspec Syndicate #00085
Bumpkin_95
Post by Bumpkin_95 »
I love my 237 good luck with on your fettle. Those Zebco globes are kinda cool. I believe I would hang on to it. You don’t see them every day anyway. Keep us posted on your
Progress.
  • Lee
  • ICCC member #1927
Oh man. That fount is gnarly! Good luck with that one.
I hope it holds up for you, Eric; at least it's just kero.
South Eastern Pennsylvania
Nice lantern. Dicey bottom.
CoolPro
Post by CoolPro »
237's are the bomb. Hope this is not a bomb! All the best to you in slaying that rust. Great save!
Cheers!
CoolPro - Kelly In Alberta
Novice Fettler
sleebus
Post by sleebus »
Yeah, that looks just like a 242c that I picked up. I would put a splash of Kerosene in it and see if the bottom gets wet. Easiest way to tell for me. I also have a small ballpeen hammer that I lightly tapped the bottom with...and it went right through. Wasn't able to push through with my thumbs, but the light tap had no problem.
Emorr123
Post by Emorr123 »
Put some steel wool to the bottom and knocked off the surface rust. No apparent holes. Put some kerosene in it...bottom is dry! Now onto some cleaning and see if she fires up🔥
Eric
MilspecOps #1272
ICCC #1789
sleebus
Post by sleebus »
I'd check 'er again after you get a bit of pressure in 'er, but maybe ya got lucky!
brokenmantle
Post by brokenmantle »
good save.
BillG
Post by BillG »
Nice save Eric....good luck with it!
Toronto, Canada
Paddywonka
Post by Paddywonka »
Decent vent on that one for a 237. Those Zebco globes bring a premium on ebay.
Had a nice looking 237 & a 249, both with a beautiful founts, they had less then just a splash of rust on the bottom. Completely fettled the lanterns, flushed tank & the works. Put pressure to them, set them on plates, and let it set overnight to see if it held. The next day the plates were covered with kerosene, no pin holes just seepage. Now I really pressure them up first before fettling.
Emorr123
Post by Emorr123 »
Pressure test overnight. Only seepage was from the valve stem...simple fix. Looks like the fount is ok.
Eric
MilspecOps #1272
ICCC #1789
sleebus
Post by sleebus »
Emorr123 wrote: Wed Feb 24, 2021 7:38 pm Pressure test overnight. Only seepage was from the valve stem...simple fix. Looks like the fount is ok.
Awesome news! I wonder if painting that up with a few coats of naval jelly would be a good idea to stop the rust?
Good news Eric! Keep an eye on it.
Emorr123
Post by Emorr123 »
Eric
MilspecOps #1272
ICCC #1789
Emorr123
Post by Emorr123 »
This is what the bottom currently looks like. I would like to coat with something without painting it...would naval jelly be the best option?
Eric
MilspecOps #1272
ICCC #1789
Paddywonka
Great to see it up & running! 237 is one of my very favorites. Maybe first neutralize the rust without scrubbing too hard. Maybe kerosene with a tooth brush, let set & repeat. Let dry & a few good coats of paste wax. Too aggressive & you might get a leak or seepage. Nice job!
Emorr123
Post by Emorr123 »
Thanks! And thanks for the suggestions for the bottom.
Eric
MilspecOps #1272
ICCC #1789
sleebus
Post by sleebus »
After thinking a bit, I believe that naval jelly is a good way to go. If it leaks as a result, you likely prevented an accident...because that means you wern't for from one in the first place! After the rust conversion, I'd coat with CLP, ACF-50 or similar. You need an oil or similar that leaves a coating to keep water out and stop the rust from forming again...in my opinion, I don't think that car wax is up to the task for this.
Bumpkin_95
Nice save. You definitely pulled that one back from the brink of death.
  • Lee
  • ICCC member #1927
