Smarter than this Aladdin
- Serious Colemanaholic
I have 4 Aladdin lamps Model12, "B" and "C" burners, All new wicks and mantles all work and filled with fresh klean heat The 12 is by far the easiest and brightest. The B and C are more finicky. I find them very difficult to dress the wick to get rid of any low spots or spikes. which make it less consistent light on the mantle and even after a long warm up 1/2 to 3/4 hour they can be prone to spotting the mantle at the spikes if turned up enough to be good light output. . I have two Aladdin wick cleaner/dresser's I spent some time last night with two lamps and never got a nice consistent blue flame and there for did not get a nice consistent bright mantle. . Any helpful tips besides more time tweaking the stupid wick. The burner/spreaders and all the holes are spotlessly clean. The newer mantles seem to be less consistent and not perfectly formed either.
ICCC 1868
Perfection appreciation #10
Milspec 65252
ICCC 1868
Milspec 65252
Re: Smarter than this Aladdin
Ugh, I have the same problem with a B burner. I've trimmed the wick level with a razor blade several times, and it still wants to burn one side low and the other is high. Driving me crazy. I always end up with one side of the mantle glowing and nothing on the other side.
I don't think Aladdin's are good at maximum brightness. I've only been using my Model B burner, and am impressed how well it works. No flame-ups, unless I try to get maximum brightness from it. I will normally go to maximum brightness and then back way off, but this is really to prevent a runaway flame.
As far as the mantles are concerned, I've not heard of anyone praising the current manufacture of them. With no competition, they probably won't get any better. What's annoying is that the prices are going up on these, and they're expensive to begin with!
As far as one side burning low and the other high, I have a Rayo that does that upon raising the wick. What works for me on that one is to raise the wick more than I want to burn it at and then lower it where I want it to burn. It's worth a try.
I'm not a big Aladdin fan, but I know they have to be spotlessly clean. All the air holes need to be cleaned and wick good and even... Rayo's are so much easier in my opinion... Or a light switch for that matter
But the Aladdin's sure have a nice look to them.
Maximum bright is not easy and a recipe for a runaway If left at max. The more even I can get the illumination the brighter I can run it safely, and uneven brightness is difficult to get anything near to good illumination. My "C"'s are better than my "B" but my "12" is the best. also All lamps I own have the standard height Lox-On low altitude chimney .
ICCC 1868
Milspec 65252
ICCC 1868
Milspec 65252
I've swapped all of my Aladdins over to B burners. I don't have runaways with Bs like I have with others.
As for getting them to burn evenly, I index my gallery to the burner and pick the one out of three that works the best.
Based on the comments I broke down and used a razor blade and cuticle scissors and magnifying glass to trim and fine tune the "B" burner on my Washington drape and finally have it pretty decent. The mantle is a bit off kilter/distorted but Oh Well. I had it lit and put out three times and kept trimming down the high or spike after it cooled but is pretty even now. I sure like them once the bugs are exterminated. Next will be my Caboose with a "C"
ICCC 1868
Milspec 65252
ICCC 1868
Milspec 65252
