Mystery Tiny Tools-What are They?
austin65uri
Post by austin65uri »
My wife got these in an assortment of miniature building items for her dollhouse projects.
Tiny, well made of brass, and nicely knurled. One has replaceable cutter blade inserts and the other replaceable needle points. A 3/16" square opening for some sort of driver and a knob to tighten the tools to the driver. I give up, any thoughts?
Bill.
ICCC#1601
"Small earth, big universe!"
Re: Mystery Tiny Tools-What are They?
Beam compass
Imagine a bar through the square holes. Lock the thumb screws down at a given distance apart. Set the point in the center of your circle and scribe the outside of the circle with the blade.
What the intended material for them might've been is lost to time, but you could lay out plenty of doll house table tops and bar stools with it.
Yes, if I built a doll house, it'd have bar stools.
Nice catch, I’d definitely say a beam compass.
kellyblues
Post by kellyblues »
Yep, beam compass. I've got an assortment of them.
Milspec syndicate #0044
ICCC member # 1154
I'd call those "trammel points" which is another way of saying "beam compass".
RobSchroff
Post by RobSchroff »
Yeah, beam compass
austin65uri
Thank you guys! Hot-Diggity, she does have bar stools.
Bill.
ICCC#1601
:lol: Bill that's perfect!
Awesome bar stools. 😄
Post by Dmacp »
Regarding the beam trammel-
they are usually stored slipped over a small wooden dowel as the beams can be quite long and are often home made. There are usually several sets of points-straight, curved, hole centering, cutter, ink nibs, pencil leads etc. Included, sometimes attached to the heads. Also there is usually a thumb wheel adjuster.
What you have appear two be two of the primary (center) heads, with points/collets but they could also be small scribers or cutters.
Here is my miniature Brown & Sharp beam trammel-about 4-1/2 inches long an dating to the thirties. You can see the attachments in the box. This trammel comes with a beam.
Notice the thumb knob for the moving point when drawing or laying out a circle.
These were made to be set with a shop scale and can be set quite accurately, especially if you have good eyes.
austin65uri
Thank you Dan! Hmmm, maybe those might be fun to collect. :)
Bill.
ICCC#1601
grob
Post by grob »
Bill, hopefully you have the beam, or you might find some brass stock to fit. Nice Beam Dan.
Here is my Tacro Beam Compass. The top of the beams are knurled to wheels in the heads. Bottom of the box is a blade, a ruling pen, a clamp for pencils, rapidograph pens, etc. a beam connector and leads and points. Below the box is a green 3ft. beam. Photos below that is a compass I made for my router. Gar
- Foghorn Leghorn
