237,249,237
kellyblues
237,249,237
Post by kellyblues »
Saturday night Keros.
Almost got that red rising sun globe clean. Couple more times and I'll get it. The new to me 237 runs good. It's rough and going to be my beater 237. I'll polish the nickel after I get my shopsmith home from the storage unit. I tried using my hand buffer and stopped because I kept thinking I was about to burn through the nickel. I've used that shopsmith for polishing for 25 years, it's what I'm comfortable with. So this one gonna wait.
Milspec syndicate #0044
ICCC member # 1154
smarti
Re: 237,249,237
Post by smarti »
Two stinky boat anchors and a good user. They look nice though, as long as I don't have to smell them. I prefer a 236 all day, every day.
It was Love at first light!!! Scott
kellyblues
Re: 237,249,237
smarti wrote: Sun May 02, 2021 1:13 am Two stinky boat anchors and a good user. They look nice though, as long as I don't have to smell them. I prefer a 236 all day, every day.
No offense but you must be doing something wrong. :lol: :lol: I've had the 237 on the right for years and years. It runs good and clean. I've had several 237's & 236:s. I enjoy them both
ICCC member # 1154
kiwi
Re: 237,249,237
Post by kiwi »
You have good taste in lanterns, don't listen to those that say they are smelly, I know as well as you how clean they are to burn. Kerosene is only a problem if you spill some.
I have a beater 237 that it is my best burner and it is far more of a beater than yours.
It had hung in an open barn for years, covered in rust, dented and absolutely filthy, I bought it to save it.
I use it as often as I can just to prove the naysayers wrong.
Geoff
Kiwi
Re: 237,249,237
Lookin good! Those three are nice and bright.
Re: 237,249,237
Post by Dmacp »
The stink is coming from mixture leaking out of a threaded fitting or slip joint. Burner tube to burner cap is one major offender on the 237. A drip slow enough that the heat will vaporize the kerosene is another.
Permatex muffler and tail pipe sealer on the threads will do it. There should be no unpleasant odor. Just clean hot CO2. Kerosene lanterns are not the only offenders. The 200A is very similar.
Re: 237,249,237
My 237-based Keggeratern burns perfectly clean and with no stink--even running on ULS Diesel. Too little pre-heat will give you a stink for a minute or so, and sometimes it'll outgas a bit when shut down.
kellyblues
Re: 237,249,237
kiwi wrote: Sun May 02, 2021 6:01 am You have good taste in lanterns, don't listen to those that say they are smelly, I know as well as you how clean they are to burn. Kerosene is only a problem if you spill some.
Thank you. Yeah I've been doing this gpa thing for a little while.....lit my first kero before 1980 so they aren't a struggle for me. Like the milspecs. It's always nice to have a beater .
Dmacp wrote: Sun May 02, 2021 5:07 pm
Yes sir, spot on.
Gunhippie wrote: Sun May 02, 2021 5:48 pm My 237-based Keggeratern burns perfectly clean and with no stink--even running on ULS Diesel. Too little pre-heat will give you a stink for a minute or so, and sometimes it'll outgas a bit when shut down.
Too little pre heat is something I think lots of people are guilty of. I fill the cup to the top and wait till it's dang near out before I open the knob. Normally I'll turn the tip when the cup is a little past 1/2. Something I learned a long time ago is when the gen starts getting dirty I'll fill the cup before shutting the valve all the way and make sure any left over kero gets turned into light. When I first started doing that I wondered if it caused the gen to clog up faster. So I did some tests with a couple 237's and found it actually helps. So I got in the habit of buring a cup on shut down every once in a while and it extends my run time between gen cleaning.
ICCC member # 1154
Re: 237,249,237
Post by Dmacp »
I don't have that problem because I'm in SoCal where it's hot. But I sure have in the Sierras when it is not. In fact, I ran a 237 with a screen globe and it was so cold that the lantern lost it's preheat and went out. Now there is where the odor will get you. Wow. Smelled like an F86 taxied through the tent.
kellyblues
Re: 237,249,237
Dmacp wrote: Mon May 03, 2021 5:40 pm
Yeah that will get ya. Lol. I did the same thing in Indiana one winter. I don't care what kero lantern it is, not enough heat and it stinks. But I live in Florida now so I doubt I'll have that problem again.
ICCC member # 1154
Re: 237,249,237
I've had a 200A with screen globe, burning CF, stop generating on a below-freezing, breezy night--but it didn't go out. It fireballed. Fortunately, I was standing right there and got it out before the picnic table was consumed, but I did have to re-paint the lantern.
