any M1950 founts out there ???
kinda itchin for a fount . i think thats all i need :-) all nos parts there . nice to find a NOS fount . there is a guy with nos canisters on the bay , its on my want list . but im not a stovie !!!
Re: any M1950 founts out there ???
You should ask in the classified section
Pancholoco1911 wrote: Sat May 29, 2021 8:10 pm You should ask in the classified section
PHC2MCC
Post by PHC2MCC »
Steve I have a used one you can have. It’s missing most of the paint and is a complete stove. I’ll send you a pic in a little bit.
Spencer
Spencer,
If you end up parting it out, I may be interested in the pump and valve. :)
PHC2MCC
Post by PHC2MCC »
I’ll let you know if Steve passes on it Jim.
Spencer
Steve - are you looking for any particular year or manufacturer?
Jim - Do you need all of the pump parts and all of the valve parts?
Steve,
I bought a stove a few years ago that was missing the pump. I got it for the valve shaft because I had broken the valve shaft in mine removing it from the fount. Seeing Spencer having a stove he may not want got me to thinking I could build another with the valve shaft and pump. Not that I have any need for another stove. :)
Jim - If it was about need I'd have been done getting stoves about 65 stoves ago. :-)
So you just need a pump and a valve stem? If you can't get the parts from that other stove, let me know. I might have what you need.
Hahahaha true.
That's a cool stash of parts Steve. Hopefully you find a nice fount that you can build off of. I'd love to find a good user M-1950.
i replied to Spencer :-) if he has no want for that stove ill fix it up , but it probobly wont need too many parts to get it going ............i dont use NOS stuff unless i have too , some of those parts came from OCP just recently . Mike has pumps available ....i might have a used usable bare valve shaft Jim but no valve .
oldscout33597
Post by oldscout33597 »
Do you have one of the control valves that screws in the tank and looks like a tee that holds everything together
ya , thats a complete NOS M1950 valve i just got like a week ago from OCP , i think it was the only one available at that time . it didnt come with the knob , or burner cone , had to buy those separate . so im putting together a kit of sorts . have a complete nos pump , generator n clip ..... i think i have everything to make up a stove , even the decals ...... if i see another ill let you know ........i have a couple used ones but there too bent up , might be able to save the valve shaft but the vale body looks buggered .
i kinda go on spurtrs with this coleman stuff , right now its single burner stoves :-)
i recieved a complete M1950 today , looks a little rough , but i have everything to make it nice once again . thanks Spence !!!
i could not get good smooth action on the excentric block in the original valve , i tried a few different excentric blocks , the nub on the valve shafts were all worn so i broke down and used the Nos valve from OCP . now nos isnt always just a straight swap . i dont know why they sell a complete NOS M1950 valve assembly , they seal the valve shaft conection to the valve body real good BUT you have to take it all apart to install em , that valve shaft has to come out to install the valve ............ok it was getting tired and i knew better but i tried to use the NOS gasket on the fuel and air assembly , basicly thats the on n off seal for one of these , well it was no good and i had to take it apart once again . at least everything was clean this time . its a 1966 coleman M1950 . .. a few paint ussues but looks decsent to me , added a clip on genny , a wrench , filled the pump bore back up with spare parts ........now one thing i dont think many have noticed are actual coleman M1950 generators have a small "C" stamped on the side of the vaporizer shell . so i put all 3 coleman generators on this one .
