wonder why coleman eliminated the legs off the 425 stove
thesunshineofthenight
Post by thesunshineofthenight »
Re: wonder why coleman eliminated the legs off the 425 stove
Probably to use less material, just as easy to stamp big depressions on the bottom of the stove case to act like legs.
UncleFred
Post by UncleFred »
Everyone's Favorite Uncle
Coleman Leacock 635B721 Alliance #8
nymtber
Post by nymtber »
Do the old models with legs have the heat shield under the burners? I thought those were added when the legs were removed. My 425E doesn't seem to get too hot underneath.
Stovie
She's Got Legs
Post by Stovie »
I was wondering about that, why the 425D has the red legs, or if there is any utility at all from extending the stove a couple inches above the table surface. I can't really think of any benefit.
Everybody wants to drive the train, nobody wants to shovel the coal.
Zulu Kono
Title: Like a Butterfly A Wild Butterfly
Post by Zulu Kono »
Legs
Post by Legs »
My 425NL is my favorite small cased stove and works well. No added heat deflecters and the legs do a good job holding the lid closed and setting upright.
Let it burn....
Don... Oregon
Coleman Slant Saver 007 Coleman Quick Lite Crew #61  ICC #1438   NRA #147137741
I've melted the top of a Roll-A-Table using my 426A with the legs extended. I don't know how well the heat shield on the newer stoves works, but....
Post by ecblanks »
The legs, to me, are a bit problematic.
The straight legs of the NL and B are just awful. The crooked legs of the C and D are better, but you still have a very narrow support base that can be an issue on things like picnic tables. I'm sure more than one person had some form of an accident while not setting the legs up proprerly. I'm guessing when they went to a latch system (the legs also hold down the lid) they saw an opportunity to ditch the legs. That said, my favorite user stove is the 425D.
Carlton
ICCC Member #1892 (expired)
williamlee111
Post by williamlee111 »
Kgam1020 wrote: Tue Jun 08, 2021 9:51 pm Probably to use less material, just as easy to stamp big depressions on the bottom of the stove case to act like legs.
+1
