CQ Pump, DIY
grob
CQ Pump, DIY
Post by grob »
Thought this up last night and then ran across JimL's post in technical about a DIY pump using a Dollar Tree pump and a valve stem. Here is my retrofit version. It's the conical rubber tip from my blow gun to a connector F to F to a Schrader fitting with the valve removed. The pump is my emergency mountain bike pump which locks down on either a Schrader or Presta valve. Still might get a Dollar Tree pump though.
The conical rubber tip is a good seal to the CQ valve. Not sure the check valve is working proper. The pump works both ways, but still took quite a few pumps... small volume.
Cost: $0 (had the stuff)
Gar
JimL Pump DIY link:
viewtopic.php?f=6&t=18257
And the proof. Blow gun with another tip removed:
Coleman Quick Lite Crew #60
- Foghorn Leghorn
Re: CQ Pump, DIY
That’s a pretty good idea Gar! Hey if it works, it works!
grob
Re: CQ Pump, DIY
Post by grob »
Hey Ken, ya, too simple. I was using a short hose from a portable tank. Too much stuff and PITA! Have to make another set, so I can put all those parts back where they belong. -G
- Foghorn Leghorn
grob
Re: CQ Pump, DIY
Post by grob »
Here is a pump I just found on Amazon with a conical tip, $4. I was at a Dollar Tree just now and could not find the pump.
https://www.amazon.com/Sports-Inflation ... 0254580513
- Foghorn Leghorn
