BB Shake Option?
Dremwolf
BB Shake Option?
Post by Dremwolf »
Mil-Spec Ops #1988
Re: BB Shake Option?
Lol 😆 that’ll work
Dremwolf
Post by Dremwolf »
Kgam1020 wrote: Fri Jun 11, 2021 4:48 pm Lol 😆 that’ll work
I'm getting tired shaking this 118a fount. Maybe that will work quicker???
Mil-Spec Ops #1988
gwillmot
Post by gwillmot »
What's interesting is that I've purchased over 80 lanterns and two stoves and have never used ye ol BB shake.
Luck .... maybe, but then again ... is it really necessary or just a habit?
:cf_idontknow:
P.S. - They ALL function as originally intended.
Still Crazy After All These Years
Mark 16:16
"I'm getting tired shaking this 118a fount."
Well then, stop. What you are doing is mostly ritualistic behavior.
Dremwolf
Post by Dremwolf »
gwillmot wrote: Fri Jun 11, 2021 5:00 pm What's interesting is that I've purchased over 80 lanterns and two stoves and have never used ye ol BB shake.
:cf_idontknow:
With the 118a I recently acquired it sure is need. I've already run more than a gallon of gasoline through it and I am still getting junk and muddy colored gasoline when I dump it.
Mil-Spec Ops #1988
Dremwolf
Post by Dremwolf »
zoomkat wrote: Fri Jun 11, 2021 5:02 pm "I'm getting tired shaking this 118a fount."
So just leave all the junk in there and call it a day?
Mil-Spec Ops #1988
Ralph get your fount clean. Your 118 has a screened pickup and will give you fits if it's not free of impurities. Don't listen to the naysayers... Sometimes they just wish things better...
"So just leave all the junk in there and call it a day?"
You need to get works for you. ;)
kellyblues
Post by kellyblues »
Ralph do what ya gotta do. I for one use the bb shake when it's needed. Works wonders.
Milspec syndicate #0044
ICCC member # 1154
The hardest part of the bb shake is getting that last damn one out. Lol.
Dremwolf
Post by Dremwolf »
kellyblues wrote: Sun Jun 13, 2021 10:53 am Ralph do what ya gotta do. I for one use the bb shake when it's needed. Works wonders.
Well the muddy gasoline is starting to look like tea. So hopefully the end is near.
Mil-Spec Ops #1988
gpaguy
Post by gpaguy »
You would probably end up with a hammer tone finish on the inside of your tank. I've always been a fan of coarse thread screws anyway.
Dremwolf
Post by Dremwolf »
mksmth wrote: Sun Jun 13, 2021 11:14 am The hardest part of the bb shake is getting that last damn one out. Lol.
I was already dreading that since I could not drain all of the gasoline out after the first flush. I found a good magnet that will fit in the fount and already tried neodymium magnets on the bottom to keep them in one place. The other option on the table is tubing and the Shop-Vac. :idea:
Mil-Spec Ops #1988
Dremwolf
Post by Dremwolf »
gpaguy wrote: Sun Jun 13, 2021 2:11 pm You would probably end up with a hammer tone finish on the inside of your tank.
And it would be hidden. Drats LOL
Mil-Spec Ops #1988
I use a little magnetic pickup tool. Good for removing the first to the last BB (I use stainless steel sheet metal screws instead). It also is good for getting the larger flakes of rust.
I wonder whether any of the hardware stores around here would mount a fount in their paint shaker to see if it works. Catch them at a slow time of day and I bet they'd get a kick out of trying it.
Stewart
"I wonder whether any of the hardware stores around here would mount a fount in their paint shaker to see if it works. Catch them at a slow time of day and I bet they'd get a kick out of trying it."
I doubt that would happen. Some random person walking and asking then to go "off script" with their equipment might entail legal liability issues if things don't go as planned. If a person needs a mechanical shaker, maybe start making one using a jig saw or a reciprocating saw. Light some incense to round things out.
Dremwolf
Post by Dremwolf »
zoomkat wrote: Sun Jun 13, 2021 4:45 pm "I wonder whether any of the hardware stores around here would mount a fount in their paint shaker to see if it works. Catch them at a slow time of day and I bet they'd get a kick out of trying it."
I was thinking the same if using a flammable liquid and the fount developed a leak during the earthquake shake. Not a good thing. Sitting out in your own backyard, maybe not so much.
Mil-Spec Ops #1988
I made a rattle can paint shaker - I had to "tone it down" as it busted the feed tube off a couple!
(Spraying upside down is sort of weird... - Hmm I have a couple that are clogged inside. maybe I need to deliberately bust em? Hmmm)
Dremwolf
Post by Dremwolf »
outlawmws wrote: Sun Jun 13, 2021 5:20 pm I made a rattle can paint shaker - I had to "tone it down" as it busted the feed tube off a couple!
Hey, that's an option to get the last drop out.
Mil-Spec Ops #1988
TSPORT
Post by TSPORT »
:cf_idontknow:
Necessary? I have a 220 that I bought just to get the case. Has the red lining in the fount that is more wrinkled than the face on a Shar Pei dog. I’m gonna need a BB shake, rattle AND roll to get it cleaned out (plus a good amount of denatured alcohol). I use screws and nuts instead of BBs.
"Has the red lining in the fount that is more wrinkled than the face on a Shar Pei dog."
Does the lantern run as is? Just asking for a friend...
mgmlvks
Post by mgmlvks »
A clean fount is a happy fount. Need to slow down the shaking and ensure no movement of the fount or it gets a wear mark or goes flying. Rotate into different positions as well
I've done both, some need it -some don't - I'd guess high humidity areas more often than dry areas...
I'l use BB's if its a lot of crusty stuff, but if not, then Evaporust is the way to go...
TSPORT
Post by TSPORT »
zoomkat wrote: Sun Jun 13, 2021 5:52 pm "Has the red lining in the fount that is more wrinkled than the face on a Shar Pei dog."
Haven’t tried to light it. It looks a mess inside and out. Another project for the wintertime.
