Vulcano (German) Alcohol Stove? Any one Know about these?
I picked this one up last Sat at a living Estate sale.
What I've found so far:
Vulcano (yep, that's the spelling...)
Made in Germany
Burns Alcohol
Gravity feed
Possible leak sources (so far) - Cap gasket. - O ring at a hinged joint, - Valve Packing.
Has a preheat tray so that's pretty obvious. (but fill with the valve, or separately?)
the only ones I found on Eprey the label, and in one case crumpled instructions, were in German
Under the lid this one, the cap instructions awe in English
I suspect the O ring needs replacing, that looks like a PITA, as its sort of incorporated into the hinge...
The cap gasket is hard as a rock, but a std Coleman cap gasket looks like it fits fine.
Valve packing was loose, but seemed to tighten easily.
Anyone have any rebuild instructions/advice? Links? (I'm not getting much traction off Google...)
