639c kero on sale right now on amazon
1freshfind
Post by 1freshfind »
I am seeing this now 109.99 on Amazon
also in stock 119.99 on colman.com
William
Re: 639c kero on sale right now on amazon
William
That’s good to see as late last week they were not in stock.
I’m holding out for a sale like 2019 but I’m not optimistic.
1freshfind
Whitegas Extraordinaire wrote: Mon Nov 15, 2021 5:14 pm William
Yeah, not really sure what series of events need to take place for that to happen.
William
Eltice
Post by Eltice »
If you register at Coleman.com, you can receive 15% off, and they offer free shipping. Not a bad deal!
Eric L. Tice
ICCC# 1985
WTB Birthdays 6/73, 5/77, 7/08 and 3/10.
Eric,
It's not quite fine print, but the free shipping offer is if you use 'Afterpay'. "Your purchase will be split into 4 payments, payable every 2 weeks." Although there's no interest added, it's yet another entity that will have your credit card info.
1freshfind
Thanks for the info!
William
Eltice
Post by Eltice »
I used PP and paid the full whack…I’ll double check that I wasn’t charged, but my invoice shows “Free” shipping cost.
JimL wrote: Tue Nov 16, 2021 12:52 am Eric,
Eric L. Tice
ICCC# 1985
1freshfind
109 after tax is good.
William
Maybe the Afterpay is just more enticement by allowing one to pay in installments.
stoves1234
Post by stoves1234 »
The ad I saw for the 639 on Amazon mentioned a couple of times the "dimming feature" on the lantern. I have no experience with kero lanterns but somehow that doesn't sound right to me.
stoves1234 wrote: Tue Nov 16, 2021 10:50 pm The ad I saw for the 639 on Amazon mentioned a couple of times the "dimming feature" on the lantern. I have no experience with kero lanterns but somehow that doesn't sound right to me.
I’ll test that out now!
1freshfind
Whitegas Extraordinaire wrote: Tue Nov 16, 2021 10:59 pm
I tested mine last week with a 500cp Butterfly mantle and it did just fine in upper 30 degree weather at about 40 percent brightness for a few hours. I am new to these and I tested in the middle of the yard away from anything flammable. After hearing a few horror stories from pros here I do not think I will be running it like that on any kind of regular basis. Coleman support says not to do it as it is not adjustable which should translate to dimmable so that must be a misprint or coleman support didn't know what they were talking about. There is an on and off knob and it does not have a low indicator like on many of the CF lanterns with this type of knob.
William
1freshfind wrote: Tue Nov 16, 2021 11:21 pm
I’ll say this, I’m reckless 🤣
It doesn’t help that a certain percentage of fuel leaks through the crimp on the mixing chamber. This thing stinks of Kero. I find it difficult to turn it down to 40%. You turn it down and it actually gets brighter with a light meter. Turn it down some more till it’s volume changes and ten minutes later it’s at 25% of max.
These stamped burner/mixing chambers can often use a good going over, looking for possible openings in the seams and getting a little muffler cement.
I had noticed a little kero odor on mine, but not bad. When I had the vent and globe off at a gathering, someone in front of me watching said "Did you see that?. I didnt see it but when I lit it, he saw a little puff of smoke at one of the seams. That's when I broke out the muffler cement. :)
639C
Overfilled clear kero
Soft start
50 pumps
Lit and 6 minutes later measured output
Full bore 2340 Lux at 8”
At 11 minutes turned down to 509 lux set timer
Twelve minutes later my son opened the garage door, it started to change sound almost spit and sputter but ended up being brighter at 639 lux.
Yes the mantle is visually brighter and whiter.
At 28 minutes it dimmed to 7 lux and was ready to fireball .
I’m operating in a roughly 1,000 sqft garage.
JimL wrote: Tue Nov 16, 2021 11:53 pm >>It doesn’t help that a certain percentage of fuel leaks through the crimp on the mixing chamber.
That’s been mentioned before but really is sad to have to do that. Approaches ridiculously low product quality.
1freshfind
I am just getting into the kerosene lanterns and my new 639c runs good so far. I bought a second one and am playing with a 290 conversion. I think another couple of weeks and I might be done with kerosene for the most part. I don't think I want to deal with it on any kind of regular basis. I will keep a couple and a nice supply of fuel for the end of days but at this point I do not care for the smell and a gallon of CF will last me 2-3 months so the cost is not a problem.
William
stoves1234
Whitegas, thanks for posting your test results. Don't push it too far though, we want you to be around for the holidays!
It’s on sale for $89.99 direct from Coleman now.
One item of note I’ve seen postings with a 2/21 and 3/21 production date
The 2/21 have an old style pump and the 3/21 have the plastic dohickey pump.
The early 2021 dates don’t explain these being outta stock all year. Perhaps they built founts right after the Anniversary lanterns were made?
https://www.coleman.com/lighting/lanter ... 04258.html
1freshfind
Oh yeah that’s cheap
William
Quick_Cal
Post by Quick_Cal »
Whitegas Extraordinaire wrote: Sun Nov 21, 2021 3:48 pm It’s on sale for $89.99 direct from Coleman now.
Where are you seeing anything about production date's? Is there a choice?
Sears Collector #100
Quick_Cal wrote: Sun Nov 21, 2021 8:27 pm
Cal
M just watching farcebook and posts here. There are some later 21 dates popping up with the old style pumps. A 12/21 was found too.
12/21? We aren’t there yet 🤣 so must be brought by someone traveling from the future.
~Pancho~ :cf_howdyhat:
Cajuncook1
Post by Cajuncook1 »
Pancholoco1911 wrote: Sun Nov 21, 2021 8:46 pm 12/21? We aren’t there yet 🤣 so must be brought by someone traveling from the future.
Cheers,
David
Aka
Cajuncook1
ICCC member 2053
Mil-Spec Ops #1203
:cf_beercheers:
A Cajun transplanted in Texas
Eltice
Post by Eltice »
They also have the Powerhouse Dual Fuel in stock, only $82 and free shipping.
Not too bad, I guess. Lol
Eric L. Tice
ICCC# 1985
Quick_Cal
Post by Quick_Cal »
So is having the plastic pump just a no no? Can It be converted to a metal pump? Or is it not worth the effort?
CraterEddie
Post by CraterEddie »
The plastic top part on the pump is not that big a deal practically speaking. Yeah it looks cheap, but it works. Both of mine that I got a few years ago when they went on Black Friday sale (back in 2018 and 2019 I think) are the plastic type and I have had zero problems with them. I'm thinking about grabbing another one at this price just to have another new one. These things are very reliable and hella bright.
When I get home tonight I'll check the build dates on my two.
Edit to add: 03 - 18 and 08 - 19
Northman49
Post by Northman49 »
The ad shows a Propane carry case...is that included in the deal?
                 ICCC no.1880
                 CANADIAN BLUES Member #023
                  Mil-spec ops #1982
Northman49 wrote: Wed Nov 24, 2021 12:45 am The ad shows a Propane carry case...is that included in the deal?
Unfortunately No!
