How many years do you get out of a lantern or stove?
1oldfart
Post by 1oldfart »
How many years do you get out of a lantern or stove before something breaks on it?
Title: ECCENTRIC BLOCKHEAD
Re: How many years do you get out of a lantern or stove?
Post by brucesheehe »
THEY LAST FOREVER!
Mom and Dad's 220E and 443 from the early 60's are still going strong. Just a little PM every year or so and they are the Timex of GPA's. The take a licking and keep on ticking!
sleebus
Post by sleebus »
With the older needle-type valved items, there's so little to go wrong with them. It's likely the fount will be the item that fails before anything else. I've seen plenty of real oldies running just fine.
Post by ecblanks »
I regularly light my fettles, and it always amazes me the issues I find a few months down the road. Usually it's just a check valve or a pump cup needs to be redone (probably did't do it right the first time).
Carlton
ICCC Member #1892 (expired)
To infinity and beyond (Buzz Lightyear).
arizonacamper
Post by arizonacamper »
When I go camping my lanterns and stoves are all from the forties and fifties. My backup stove is from the early sixties.
Coleman stuff lasts forever if maintained.
"The truth is that most of us don't know what direction we are going until we arrive there."
"Young enough to know I can
I.C.C.C. #2043
gootsch
Post by gootsch »
8 years ago I took my '63 502 stove on it's golden anniversary tour of about 10,000 miles. Looking forward to taking it on it's 60th birthday tour in 2023, 15,000 miles this time. It was the only stove that I took, I have that much confidence in it.
Gootsch
parris001
Post by parris001 »
Treated correctly............ they'll last a lifetime. Mantels and fuel pump cap gaskets will fail. But these were made before the concept of designed obsolescence was part of the zeitgeist.
Yosemite John
Post by Yosemite John »
My dad's Camping Pals are from the early 1950s and still going strong :cf_absolutely:
A Happy Camper
gwillmot
Post by gwillmot »
105+ years and counting on lanterns ...... IL
Still Crazy After All These Years - Glenn
Mark 16:16
D421
Post by D421 »
Older designs will out last me. With very little maintenance lot added parts.
Newer models last as long as an O ring. :D
Dominic
ICCC #1992
Let's see... I have four lanterns that are over 100 years in age. All run perfectly. One has had the fount replaced.
My oldest stoves are from the early '30s. They still do what they do so well.
sleebus
Post by sleebus »
parris001 wrote: Wed Nov 17, 2021 3:42 pm Mantels and fuel pump cap gaskets will fail.
I've been surprised at how long a mantle will last if ya don't beat it up. I know this isn't a record or anything, but my back-porch user has got mantles going on 2 years now and they're still perfect. Trust me, that lantern gets USED. It's my primary light for cooking or going out in the back yard. I've got a table lamp that has had bugs trying to hit the mantle for almost a year now, and it's also fine.
Have to say i'm impressed at their durability.
You may want to define 'something breaks'. A mantle can last from seconds to years. The 200A in my car kit still has the Coleman mantle it had on it a few years ago. A globe can break, typically out of carelessness. Other than that, I consider it all maintenance.
If you're one that has issues with a mantle prematurely breaking, I suggest trying what a Peerless rep told me a few years back, and that is, after burn-in, to light a new mantle with very low pressure. After that, pump it up all you want.
brokenmantle
Post by brokenmantle »
it should be how many humans will a lantern go through.
bp4willi
Post by bp4willi »
Have a wickie from 1897 = 124 years.
Pressure lanterns came later.
brass bender
The oldest one I have that I know the full history on was my dad's 1973 228F. It has had many mantels. I changed out the original globe a few years ago for an amber one. Still has the original fuel cap gasket, but I'm betting that will need replacing soon...
Bouncing between California and Washington....
bp4willi
Post by bp4willi »
Would be interesting to know, how many generations will pass on my HC lightning bug.....
brass bender
I have 3 stoves that re in the edge of the century mark. Two of the lanterns I take camping all the time are both over 80. I have a couple more that are closing on 90...
Weirdnerd
Post by Weirdnerd »
I have a 1919 lamp that only needed a fuel cap gasket to run.
Werner
Loganeffecto
Post by Loganeffecto »
Depends. Usually when the fuel runs out I just throw them away.
Loganeffecto wrote: Thu Nov 18, 2021 3:09 am Depends. Usually when the fuel runs out I just throw them away.
Weirdnerd
Post by Weirdnerd »
Well....💩
Werner
I'm gonna say 30 years for post-1975 GPAs with a schrader valve. That's about how long it was from the time I bought my 400A and 290A before they needed schrader valves. Otherwise, nothing has ever broken on them.
REJ2
Post by REJ2 »
Still counting............
RLW-67
Post by RLW-67 »
Mom and Dad bought a '68 426D and a '71 200A new, and they're still ticking with minimal preventative maintenance.
Ron. :cf_flag_usa2:
ISO bday lanterns- 12-44 & 07-94
275 Turd Herder Appreciation Syndicate #1313
Back in the day Coleman was a name well recognized and a brand people could trust. Other than replacement of consumable parts, i.e. mantles, filler cap gaskets, an occasional leather pump cup maybe a broken or cracked globe now and then; Coleman lantern and stoves have been cooking meals and providing light for generations. Properly maintained and cared for I think any Coleman stove or lantern made prior to the mid 1970s can be depended upon for decades of faithful service.
bp4willi
Post by bp4willi »
Just avoid colemans with rubber seal at shaft. You simply don't know, when it will fail.
brass bender
REJ2
Post by REJ2 »
bp4willi wrote: Thu Nov 18, 2021 9:32 pm Just avoid colemans with rubber seal at shaft. You simply don't know, when it will fail.
Easy fix, if your talking the neoprene cup.
Stovie
How many years
Post by Stovie »
Wonder who it was that thought a good idea was to replace the leather pump cup with those things, some bean counter maybe? "If it works, don't try to fix it."
I always give 100% at work. 20% on Monday, 20% on Tuesday, etc
Vintageish
Post by Vintageish »
Been around 40 years on a previously well used 200A. Don't know how many more it or I will see.
But my money is on , the lantern will survive me.
I think the bottom line answer is for a properly maintained GPA (replacing consumable parts) is:
We don't know how long they will last, they have not been around long enough. With minor exceptions, if not abused they have not seen an "end of life".
One exception: certain brand brass founts have stress cracking issues. That's a design/manufacturing problem, not a GPA general problem.
Newfie
Post by Newfie »
If you're using clean fuel I'm thinking the only thing that will ever go wrong is a dry pump cup or fuel cap seal. Oil the pump and replace the seal and you should be good to go.
Moses_Yoder
Post by Moses_Yoder »
I am beginning to be more concerned about how many years the lanterns will get out of me.
Moses D Yoder/Mose/Mo/Nasti /Smokin' Mo
Sears Syndicate # 651 / 275 Appreciation Syndicate #159 / Slant Saver #22
Psalm 97:11 Light shines on the righteous and joy on the upright in heart.
uvarmint
Post by uvarmint »
What he said.
Post by Bill »
Before something breaks on it? Hmmm, I once bought a 288 lantern from a Craigslist ad, brought it home, took off the vent to check something, then promptly turned the lantern upside down to read the date on the bottom of the fount. The picket fence globe fell right out onto the concrete floor of the garage and unceremoniously shattered. So to answer your question, I'd say three hours.
Marmock
Post by Marmock »
Mine will be around longer than I’ll be alive I’m sure. I have a 242b 12/40 that’s my moms bday lantern. Outlasted her.
1oldfart
Post by 1oldfart »
Wish I could get that many years out of a vehicle if Coleman lanterns last that long without much breakdowns!
