Burn time for Coleman 500A?
Cajuncook1
Post by Cajuncook1 »
Anyone with knowledge of the burn time of Coleman 500A? Want to do some outdoor cooking in Oct/Nov/Dec.
Thanks guys for any information.
Cheers
David
Cheers,
David Aka Cajuncook1
ICCC member 2053
Mil-Spec Ops #1203
:cf_beercheers:
A Cajun transplanted in Texas
D421
Re: Burn time for Coleman 500A?
Post by D421 »
David
I use mine one or two times a week. It seems pretty good on fuel. But I think it's a question that would be hard to answer due to how far you have the fuel valve opened. They go from a nice simmer to a real roar and everything in between.
Dominic
ICCC #1992
"Anyone with knowledge of the burn time of Coleman 500A? Want to do some outdoor cooking in Oct/Nov/Dec."
I'd suggest you take it out and try it out now so you can see for yourself how it works under your expected conditions. Just use water in it instead of food.
Stovie
Post by Stovie »
It won't burn for three months, I reckon. :)
It is sad that governments are chiefed by the double tongues
I've run mine flat-out for three hours, but I can't say how much longer it would have gone. I do know that I fill my 500 and 500A infrequently when using them for cooking, which is rarely if ever flat-out.
Cajuncook1
Gunhippie wrote: ↑Tue Sep 20, 2022 4:26 pm I've run mine flat-out for three hours, but I can't say how much longer it would have gone. I do know that I fill my 500 and 500A infrequently when using them for cooking, which is rarely if ever flat-out.
D421 wrote: ↑Tue Sep 20, 2022 3:24 pm David
Thanks, for the information 😎
Planning on cooking some gumbo, stews, and chili.
I like to slowly cook the beef and pork stews. The meat just falls apart in you mouth.
Cheers
Cajuncook1
Cheers,
ICCC member 2053
Mil-Spec Ops #1203
:cf_beercheers:
sleebus
Post by sleebus »
Cajuncook1 wrote: ↑Tue Sep 20, 2022 12:03 pm Anyone with knowledge of the burn time of Coleman 500A?
I think I can help out here, but we're going to have to do MATH. :shock: :mrgreen:
Ok, so 1 gal CF = 117,000 BTU. That comes to ~914 BTU/oz. The 500a holds 2 pints of fuel (32oz) so that's 32 * 914 = 29,250 BTU in the tank. The burner is referenced in multiple places as a 7,500 BTU/hr stove. 29,250 BTU / 7,500 BTU/hr = 3.9 hours at full tilt until the tank is dry. Obviously, you'll get more runtime out of it if you throttle back, but you shouldn't get much less than 3.9 hrs from a full fill, assuming that the tank can be completely sucked dry.
Michael - ICCC#2163
Check out my channel at GasUnderPressure or chat on the Coleman Discord
Now my head hurts.....................
sleebus wrote: ↑Wed Sep 21, 2022 12:27 pm I think I can help out here, but we're going to have to do MATH. :shock: :mrgreen:
Now, factor in elevation, wind speed and pot geometry . . .. I tried to make coffee on my 500A in a breeze. I had a homemade, built-in windscreen (a very fine one, if I do say so myself), and I finally gave up on coffee. I later bought one of the stand alone windscreens, but haven't yet got around to trying it with the 500A.
Stewart in
Eastern Washington State
sleebus
Post by sleebus »
TwoCanoes wrote: ↑Wed Sep 21, 2022 2:44 pm Now, factor in elevation, wind speed and pot geometry . . ..
Those factors won't change the runtime. None of those factors changes the BTU rating of the fuel, nor the BTU/hr input to the burner. Remember, BTU/hr ratings are input and not output. That's why we can take the BTU value of the fuel and use the BTU/hr of the burner figure a runtime. It will ABSOLUTELY impact the ability to transfer the heat to the things you want to heat up, but the runtime will be the same. I agree, the 500a is really adversely impacted by wind.
Michael - ICCC#2163
Cajuncook1
Thank you Michael 😊. Appreciate your thoughts and details.
So that Coleman 500A , if running properly and with a good windscreen, could give some good lengthy burn times. This would definitely help by not having to stop, cool and refill during the cooking.
Thanks guys!
Cajuncook1
Cheers,
ICCC member 2053
Mil-Spec Ops #1203
:cf_beercheers:
stoves1234
Post by stoves1234 »
The big thing is the windscreen. Gotta have a windscreen on a 500, 500A. I made mine from a stainless steel pot that I got at Goodwill. I wonder if Timm's windscreen plans survived the move?
stoves1234 wrote: ↑Thu Sep 22, 2022 12:03 am The big thing is the windscreen. Gotta have a windscreen on a 500, 500A. I made mine from a stainless steel pot that I got at Goodwill. I wonder if Timm's windscreen plans survived the move?
So true! I'd forgotten, as mine have screens.
Just in case:
Master Wysong would kick my ass up the block and back if he saw those plans!
I did a test with my 500A and they about halved the boiling time for a quart of water in a calm shop--makes even more difference in a breeze.
For cooking outside in a breeze, more windscreen is needed for best efficiency:
grob
Post by grob »
I was just camping a few weeks ago and was using my 500A with a Kamp-Site heat drum and a Paulin propane heater as I was unsure of fire restrictions. I was running the 500A at full blast and I think a tank lasted about 3 hours. Should last a long time at a low flame for a stew. I would also use a diffuser. I got inspired by Timm's wind screen and made one out of brass. Another wind screen might be good too.
Gar
Coleman Quick Lite Crew #60
- Foghorn Leghorn
Stovie
Coleman 500A
Post by Stovie »
That sure is a pristine looking stove, is that something you restored or is that pulled out of a time capsule?
grob
Post by grob »
Stovie, No it was mighty grubby. I cleaned it up and painted the frame. Here is a before pic.
$20 'cause he couldn't get to light and threw in a Gal. of CF!
O-Tay, Gar
- Foghorn Leghorn
stoves1234
Nice stove and windscreen.
You call that grubby?
$15 'cause he didn't know what it was.
Cajuncook1
Come on Cool weather! Can't wait to put my Coleman 500A time work!
Love those before and after pics guys.
The wind screen plans are much appreciated :)
Cheers,
Cajuncook1
Cheers,
ICCC member 2053
Mil-Spec Ops #1203
:cf_beercheers:
Cajuncook1 wrote: ↑Wed Sep 21, 2022 6:40 pm
Thanks guys!
Cajuncook1
If you can switch to another burner/stove for that time, you can just keep trucking while you cool/refuel.
I honestly can't guess how long any of my stoves will go on a tank. they re on/off, wait for the next meal, etc, repeat as needed so :cf_idontknow:
Coleman Blue's 243's #341 -Β 275 Appreciation Syndicate member 0242
KK No. 3 Appreciation Klub #1
grob
Post by grob »
Timm's all nickle plated 500 is the teats! Here is my screen drawing... might need slight adjustments.
Drilling holes in the brass was challenging. I also made a heat deflector for the fuel knob (1st pic).
Thanks Jim,
Gar
- Foghorn Leghorn
gootsch
Post by gootsch »
For drilling holes in thin material I use a step drill bit, much less painful than using a twist drill bit.
Gootsch
offrink
Post by offrink »
Drill press is perfect for drilling in metal. Clamped down, slow speed, variable constant pressure.
I use 500’s while out camping. One with a windscreen and one without. The one with was way hotter. It funneled the heat up to a griddle. One side was bacon the other was eggs so it works out well.
Ben
grob
Post by grob »
Hey David, I thought you might find this interesting too. I made a case for my Coleman oven and also a stand to use it with a 500 stove. I used rivet nuts and threaded rods for the stand. It will reach pizza temps of 425 degees.
Gar
- Foghorn Leghorn
That's a good mod! And I like the case!
grob
Post by grob »
Thanks outlawmws. Here is another pic. G
- Foghorn Leghorn
Bob1774
Post by Bob1774 »
I'm not sure if we've concluded how long a 500A will burn on a full tank, but this thread has sure gotten good mileage!
Love all the tips, pix, and windscreen plans.
grob
Post by grob »
By sleebus math 3.9hrs on a full tank. I was saying 3 hours full blast on a full tank, but just a guess.
Gar
Here is a boil test I did a while ago (bored I guess):
Stove Boiling Test
1/2 Qt. cold water in a Revere Ware 1 Qt stainless pot, no lid. Alt: 5,280 ft.
Main burner on 2 and 3 burner stoves.
Stove / Model Fuel Burners BTU Time
Coleman 500A: CF 1 Cast/BaB 7500 3:05.9 min.
Coleman 502: CF 1 Band a Blu 4500 4:31.6 min.
Coleman 426A: CF 3 Band a Blu 25,800 2:19.4 min. (7900, 10.000, 7900 BTU?)
Coleman 3H: CF 2 Cast Iron 10,000 est. 2:23.7 min.
Coleman 5410A: Prop 2 Band a Blu 10,000 2:22 min. (1:22.8 min. faster than Optimus 831)
Optimus 831: Prop 2 Optimus NA 3:44.8 min.
Optimus 99: CF 1 Optimus NA 4:09.4 min.
- Foghorn Leghorn
Things to remember: Coleman was optimistic about both outputs and fuel capacities. I measure my fuel when filling/refilling and come up with a few ounces short of what Coleman claims.
I fill to the bottom of the fuel bug, then measure that. Here's what I have for the little guys (suitcases take a larger measuring cup):
500/500A fount is the same capacity as the 220/228. 28 oz vs. 32. Fill too high and you'll be pumping a lot for the first half-hour--or just spilling fuel.
I don't have a way to measure output, but I'm sure the marketing guys over stated that, too.
Note that the lowest mark on my cup is for the 502 stove. I just ran one for heat with a heat drum. 3 hours 21 minutes to empty, full open.
grob
Post by grob »
Cool, good to know Timm.
Gar
- Foghorn Leghorn
sleebus
Post by sleebus »
Gunhippie wrote: ↑Fri Sep 30, 2022 1:52 am I don't have a way to measure output, but I'm sure the marketing guys over stated that, too.
Well, you could always get the stove running, weigh it, wait 15 mins, weigh again. Using the BTU content of the fuel and its weight, you can calculate the BTU used. Multiply that x4 (since it was only a 15 min test) and you'll get BTU/hr.
Michael - ICCC#2163
sleebus wrote: ↑Fri Sep 30, 2022 12:26 pm
How about 3:21 from 16 fl oz for the 502?
sleebus
Post by sleebus »
Gunhippie wrote: ↑Fri Sep 30, 2022 3:50 pm How about 3:21 from 16 fl oz for the 502?
Ah! Ok, this I can work with.
So, that's 201 mins of runtime, using 16 oz fuel. You're burning 0.0796oz/min. In 60 mins, you'll have burned 4.776oz. Fuel is 914.06 BTU/oz, so 4.776 x 914.06 = 4,366 BTU/hr. Pretty darn close to the claimed 4,500 BTU/hr. :shock:
Michael - ICCC#2163
sleebus wrote: ↑Fri Sep 30, 2022 4:01 pm
Remember, my measurements are in fluid ounces, not weight. Might have to convert that to actual ozs--which will depend on temperature, too. I'll toss 16 fl oz into the cup and weigh it today (gotta refill anyway).
sleebus
Post by sleebus »
Gunhippie wrote: ↑Fri Sep 30, 2022 7:57 pm Remember, my measurements are in fluid ounces, not weight. Might have to convert that to actual ozs--which will depend on temperature, too. I'll toss 16 fl oz into the cup and weigh it today (gotta refill anyway).
Yup, i'm accounting for that. 1 gal CF = 117,000 BTU. 117,000/128 = 914 btu/oz. ;)
Michael - ICCC#2163
FFIW, 16 fl oz of CF @ 62F weighs 11.2 oz.
