So why is the 275 called…
czechphotoguy
Post by czechphotoguy »
The Turd?
I realize it’s brown but is there something particularly specific about certain things that make it a supposed POS???
I just got one yesterday for $10 and while it didn’t have the original globe. I got lucky in a purchase today to get 3 of them (original 275 globes) with some other supplies from someone selling them on Craigslist.
So needless to say I now have this…
I have to say it was kind of wonky trying to start it as my lighter wasn’t working so I turned the valve off and let it sit for a few seconds but when I tried to relight it I got a huge fireball!
OK I will stop talking, and await further “conversation starters”!
Ross
“In Coleman cornu augue succendit superciliis off!”
Re: So why is the 275 called…
:cf_275boom:
ICCC #2197
Visit the Coleman Blues 243's Current Membership
Its an...... affectionate name. Yeah, thats it! 💩💩💩
czechphotoguy
Ridge Runner wrote: Wed Sep 21, 2022 1:37 am :cf_275boom:
OK, so I have experienced that part of it…
What else?
Ross
I've always had good luck with them myself... Granted I've franked more than I've kept whole, but of the 5 or 6 I kept original, they lit and run perfect...
I believe murff coined the name. Legend has it he was not enjoying working on one and called it a turd.
Coleman Blues 243's #171
I think that it's just because of the color and the Schrader valve in the early models. In the early models, the Schrader valve was known to fail and make shutting it down impossible until it either ran out of fuel or air pressure. I personally like the way they run. I haven't had any issues with any of mine yet.
czechphotoguy
So the crazy thing I can say about it is that the nut that holds the burner/air intake assembly isn’t anything I own for wrenches. I tried both SAE and metric and a 19mm was the “Closest” I had for it to be gently turned. The frame hold down nut is 18mm which surprised the heck out of me.
So I can understand why it might have acquired the nickname.
Ross
czechphotoguy
So where was the valve located? Under the frame rest?
Reason I ask is I have noticed that if I turn the dial all the way to the right in order to turn it off. It almost seems like it’s turning it back on so I have to back off to the left for it to seemingly turn it off?
Ross
Thedudeinboise
Post by Thedudeinboise »
The Schrader valve is located on the fuel pickup- it screws into a brass assembly in the 275. The 275A is sometimes a plastic fuel pickup tube. The symptoms you're describing lead me to believe the Schrader valve needs to be replaced- there's a little rubber seal at the end of it that's 40+ years old and likely not doing it's job.
The 275 I've found particularly difficult to break the fuel assembly from the fount. The thread locker they used seems to have cured really hard for the last like three 275s I've worked on. Break that free, purchase a bunch of fuel-safe Schrader valve cores to replace the one you got, and you should be good to go.
-Adam
-Interested in anything late '82 or 3/55
-Coleman 275 Appreciation Syndicate #1208
Murff has some very nice custom turds, and I hope he shares pictures of them.
The bail seems like it was destined for this. ;)
There are like a million "MADE UP" reasons why these are called a turd. Half of 'em think they know, and most of them think it is because it is brown. The other half of them think it is because they just don't know how to work on them 'cause they are different than 220 models. The third half of 'em are sleeping with Rod Serling (and the fishes).....
Very similar to a 220 model actually, and built like a tank. It just happens to have a schrader valve in the F/A tube, (which is made of brass, just like the earlier 220 models, so sturdy as all get out, but...
BUT..
Someone, at one time did not know how it worked, because it was an advanced design. (And man, they are a very well designed lantern, too.) Being brown is just a fluke. In the 1970s everything was either "harvest gold" (Yeller) "Avocado" (nasty green) or "Brown" (brown) and in the mid to late 1970s there were no other colors, except black or tie-dye. Just look at refrigerators and stoves/oven ranges of the time. EVERYTHING of that time was one of those colors. Also, it was like a magic time: (Shhhhhh.... Gasoline was ONE dollar for two gallons. It was a wild time.)
Well, a certain genius here, whom I love dearly despite his finger signals and mooning in my direction, just could not figure out the way a schrader valve lantern worked, 'cause he had only worked on NORMAL Coleman lanterns that had a proper Fuel/Air tube. The "new" 275, which, as I said was built like a tank, (Like an M60-A1 tank.. I'm talking like a brick outhouse, man) befuddled my beloved friend and he could not speak kindly of it so called it a barnyard name. I won't repeat that here, because I'm a moderator (for today, anyway) and my friend would probably deny it anyway, and besides he has senility over me, so I have to tread lightly. Sooooo, he couldn't get it going and kicked it to the curb while it was on fire and called it a bad name, which just don't go here, law dog, and it was translated into the word "turd".
And that's all I got to say about that.
I like my 275A, it is a solid running lantern and is very bright. Even though it is a turd ;)
And in a cruel twist of ironic fate, it was designed by Coleman to celebrate the Company’s 75th anniversary in 1975. An appropriate legacy today…
Post by MotorcycleDan »
I love my 275's. I have a bunch of them. All of them have been strong runners.
Here are a few of Murff's customs that he brought to the Bozeman Convention.
And yes, they do polish up! Here is a gold plated one that was given to the ICCC Convention host in 2021.
222, 226, 229, 3022 Collector
Weirdnerd
Post by Weirdnerd »
My 275 was a chore to make it work, but it is a dependable and very quiet lantern. If I want light and to be able to hold a normal conversation, this is the one to light.
Werner
Title: New ICCC Board President
Part-time Idito and Hater of Turd 275s, both A and non A
Current ICCC Board President
stoves1234
Post by stoves1234 »
Man, if Coleman had just made 'em in blue or red. I grew up in the '70's and just seeing a picture of a kitchen stove or refrigerator from back then still makes me slightly nauseous.
If the 275 were made in red, they would be the most sought after lantern in the world.
I know. I have a red one. It's in my bomb shelter with my 14 Garands and the old Buick Y Job. I'm set. Or, my kid is.
Murff wrote: Wed Sep 21, 2022 11:30 pm Image
H I L A R I O U S !!! 😂
Maybe everyone should just stop calling them turds? I mean, I don't call my 1980s, Coleman 400 stoves, turds.
Still laughing . . .
Tigerfans2
Post by Tigerfans2 »
Deanofid wrote: Thu Sep 22, 2022 3:53 am If the 275 were made in red, they would be the most sought after lantern in the world.
Ok... seriously? 14 M1's???
How many en blocs?
Coleman Slant Saver #58
Coleman Quick Lite Crew #8
Coleman Blues 243's #16
Tigerfans2
The definitive answer to the original question is: a Piece Of S**t is, by definition, a turd.
Next question?
Tigerfans2 wrote: Thu Sep 22, 2022 4:37 am
How many en blocs?
Four bandoleers for each Garand, so;
6 en blocs in each bandoleer, X 4 bandoleers =24 X 14 Garands = 336 en blocs. Then, 8 X '06 rounds per en bloc @ 336 en blocs = 2688 Sprg '06 rounds. Plus whatever is in all the ammo boxes. I haven't counted those.
I may not have enough to win a war, but I think I have enough to start one. A little one...
Plain Ole Chuck +
Post by Plain Ole Chuck + »
I love the looks of the 275 but mine is a little dicey to light up. Likes to burb like a dragon at times.. I need to play with it more and find out a light up method it likes...lol
Okay, it was asked for, so here we go!
1. The Green Unripened Turd. It resides in the shed with its twin (not pictured):
2. The Turd Williams! A crappy tribute to the Ted Wiilams:
3. The Gold Bond Turd with the rare Urine Yeller Globe:
4. Just a Turd but with the rare Brown Turd Globe! Only two known to exist (short of the guy that smeared $#!+ on a clear globe).
5. My favorite, "THE TURDINATOR"! Looks a lot like Arnold at the end of the first Terminator movie when lit:
6. The "Hemorrhoid", aka, "the bloody red turd"!
Dean may be right. Coleman should've made these in red!
From the 2007 ICCC Convention:
A turd for every occasion!
ICCC #2197
Tigerfans2
Deanofid wrote: Thu Sep 22, 2022 8:21 pm
How many en blocs?
At our age we don't have to win the war, just mess someone else's up🤣
Up to Light
Post by Up to Light »
I see absolutely nothing wrong with those lanterns, color, shape, etc...
Archie
Post by Archie »
I was able to find one and that’s my Birthday Lantern! 275A 5/80 my only bday lantern 😂😬
*  Archie  *
ICCC Member #2060
The Coleman Blue's 243's #580
Canadian Blues Syndicate #45
Coleman Slant Saver #03
Coleman Quick Lite Crew #511
