323 / 327 Mica Globe Information
Moderator: BobA
coleman54
Post by coleman54 »
:roll: 323 / 327
Mica globe information :
no. 323 : IL and later NL model lantern designated mica dimensions began as :
5”x 5”
no. 327 for QL: the first Quick-Lite mica with wide reflector and swinging match lighting door dimensions began as :
5”x 5” September 1916
Tabs also appeared on the vent brim base edge to help secure the mica particularly when operating the match lighting door at this time, with design bleed over to Yale YLQ January 1917,
and likely the torch lighting lanterns too with no. 323 mica.
September 1918 Coleman officially changed designation from QL to LQ, the following month torch lighting model GS 323 began shipping. Shortly after mica dimensions changed :
to 5”x 5 1/4”Height
For both the new no. LQ 327 and
no. 323 mica.
Yes Both!!!
There was also a reflector offered for the IL in this time that clasped to the frame.
Increasing mica height action eliminated the function for tabs on the vent brims after September 1918 for all Air O Lantern, transitioning was slow.
Reflector design with swinging door also started to change in this time frame 1919/20 to a narrower type that was used on Quicklite lanterns including Yale ML, and LZ through : October 1924.
The replacement mica only(less reflector) was designated :
no. LQ 327 1/2
1925 models advertising and catalogs show the new Coleman “427” debut and the 327 models with an upward sliding match lighting door still designated as : no. 327. This style mica was advertised in some years to come as six , twelve and thirteen piece mica changing dimensions to :
4 7/8”x 5 3/8” (5 1/2”) in the late 1920s and through the thirties.
Another mica designation :
no. 220 mica appears in Coleman Jobber advertising in this new instant lighting (1928) time frame labeled as a six piece mica for 220/228 also listed to fit 327/427 as well.
There are some mica examples found occasionally with Coleman branded with ink on the mica panels, and a small number with Genuine Coleman stamped frames. Some very brief advertising even described a brass framed mica for 427.
Larry
Inquiring Minds Want To Know
MilSpecsOps  #1954
Coleman 275 Appreciation Syndicate #0124
The Coleman Blues 243's #77
Coleman Slant Saver #01
Coleman Quick Lite Crew #01
LZ Lover #01
Red Vent Quick Lite Saver Crew #2
Chandelier Shanty Syndicate #8
Sears Collectors Club #16
Goldbond Collector #02
BernzOmatic Appreciation Club #003
Frank Appreciation Syndicate #007
Perfection Collectors #3
KampKook #4
Range Riders #3
Part Time Stovie
ICCC # 1412
Neil McRae “Pressure Lamp Catalog”
coleman54
Post by coleman54 »
Thanks to : Steve Retherford - Dan MacPherson - George Remkus - for their contributions and efforts for making this information available.
Larry
MilSpecsOps  #1954
LZ Lover #01
KampKook #4
Range Riders #3
Part Time Stovie
ICCC # 1412
pchamp
Post by pchamp »
Larry,
Thanks for sharing your latest research with the community. I was not aware of these variances in the mica chimneys, thanks for sharing, very much appreciated.
Paul
this info has been a long time coming , thanks a BUNCH Larry for sharing your research with us here .
just having my first cup of coffee here .
i have scratched my head for years trying to understand the notched vents and different heights of the mica's , trying my best to put or keep the correct parts on these early lanterns but not really knowing for sure..... this shared info sure makes sense to me and i may have to go back over some of my old work and see if i need to rework a few pieces ...... the one thing that is still a mystery is much of this info pertains to the date of manufacture but all of these were made before dating the founts was done , so one has to look at all the other features of a particular lantern trying to determine if its an early or late version QL or LQ .
this is absolutely the best info i have seen on this subject , cant thank you enough Larry for researching this yourself and sharing it with us all here !!! i think you deserve a PRIZE :-)
i think i recognized one of Dan's NOS 220 mica's pictured :-)
i have a nos "440" 242 sized mica that has the ink stamp .
i kid you not , when years ago i got my first 3 notched vent lantern i thought somehow it was so it could sit on top of a parchment lamp shade spider and turn a lantern into a indoor lamp , SILLY ME :-)
Image result for five stars
Very good info. Thank you very much for sharing.
Looking for additional 6-56 lanterns, anything 6-56!
There continues to be an alarming increase in the number of things I know nothing about.
Bumpstop
Post by Bumpstop »
That's some great research!!!! Fantastic info in this thread
gwillmot
Post by gwillmot »
One of the BEST articles I've come across! Mucho Bueno!
Still Crazy After All These Years - Glenn
Mark 16:16
Excellent effort went into that. Thank you.
"...follow all that I commanded you; and behold, I am with you always, to the end of the age.” Matthew 28:20
bc89801
Post by bc89801 »
Very interesting to read. Thanks for all of the work doing this!
ICCC member #1807
The Coleman Blue's 243's #145
Coleman Slant Saver #42
MilSpecOps #0037
just showing a 351 coleman mica for lamps stamped Genuine Coleman . not sure where i got this photo ?
[coleman-351]
Barryb
Post by Barryb »
Great information. Thank you very much!
ICCC #1565
Bturnbull
Post by Bturnbull »
Great read Larry. Thank you for your research on this.
i have this swirling around in my head :-)
i have a notched vent on my NL as well as a Fred 323 mica , but since there is no mica door im not sure a notched vent would have been used now ? .......back when i got a lot of my stuff we didnt have much info and i thought i was doing right , now i question everything ...... just not sure ......... oh , way back then i asked the forum but never got any good info , like the type you just shared here Larry ....i saw NL's with and without notched vents but somehow i thought the notched was early , now i think otherwise ....i highly respect your research ........... we HAVE come a long ways since then :-)
thinking of putting a no notch vent on it and putting the notched vent on a QL .
this still hasent all sunk in for me yet .
coleman54
Post by coleman54 »
Thank you Steve , for the very Kind statements! The reason I mentioned in the thread above the vent tabs in this time frame likely bled over from design of the same size QL 327 reflector mica: the no. 323 mica changed Height simultaneously in catalogs as the LQ 327. There would have been no reason to change the design size of the no. 323 if not to secure the mica on these too.
On a side note the NL designation was not listed in the new size mica listing (IL&GS only) as less than a handful were noted to be shipped afterwards and NL designation was abandoned.
Larry
MilSpecsOps  #1954
LZ Lover #01
KampKook #4
Range Riders #3
Part Time Stovie
ICCC # 1412
coleman54
Post by coleman54 »
Thank you for the kind statements. ?
Larry
MilSpecsOps  #1954
LZ Lover #01
KampKook #4
Range Riders #3
Part Time Stovie
ICCC # 1412
dbosch
Post by dbosch »
Block
Copy
Paste into Word
Save
This is excellent info. Start your Forum Save Directory. Thanks Larry!
Dan B.  ICCC #100
The Texas Dust Bowl
Post by Dmacp »
if you buy a replacement 5" diameter chimney from Fred-well, he makes them all 4-7/8" diameter so it still won't catch those tabs. Looks like I need the wide reflector on mine.
coleman54
Re: 323 / 327 Mica Globe Information
Post by coleman54 »
Here are examples of the ink branded and stamped frames :
Larry
MilSpecsOps  #1954
LZ Lover #01
KampKook #4
Range Riders #3
Part Time Stovie
ICCC # 1412
Return to “Technical Assistance Archive”
