335 fuel air tube...335 experts?
- alciuffetelli
- Member
Tearing down a Canadian 335 (2/71) that won't produce a steady fuel supply. With the generator removed and the fount pressurized, it is quite apparent that the fuel supply is intermittent. I suspect the fuel tube is the problem, so I pulled the valve assembly from the fount...but the fuel air tube really doesn't look like what I'm used to... I can't tell how to remove it. There isn't a four or six sided "nut" at the top to unscrew it, just a round wider section of tube below the threads that go into the fount. Is this f/a tube threaded onto the valve body or is it soldered?
Al Ciuffetelli
ICCC#1977
ICCC#1977
Re: 335 fuel air tube...335 experts?
A photo might help. See my other post
Pliers
Mike Trigg
ICCC#2008
FAS #013 Confusing Future Generations of Collectors, One Lantern at a Time!
Mike Trigg
ICCC#2008
" I pulled the valve assembly from the fount...but the fuel air tube really doesn't look like what I'm used to... I can't tell how to remove it."
Not an expert, but you should be able to trouble shoot possible issues with the fuel pickup tube without taking it apart.
- Northman49
- Serious Colemanaholic
Here is the F/A tube from a 335.
ICCC no.1880
CANADIAN BLUES Member #023
Mil-spec ops #1982
ICCC no.1880
Mil-spec ops #1982
Just saying that I recently was working on one of the 335 that I have and could not keep it lit when I fired it up. After partial tear down I was able to get a steady diet of fuel out of the generator by simply opening the know several turns and not just the 1/4 on the dial. Works fine now. I also try to heat my generators prior to turning on the fuel. Helps a lot to prevent fire balls.
Sorry but it's "Zed" not "Zee" for Z and a lot of "our" words end in "our" not "or" it's a Canadian thing. Eh!
- alciuffetelli
- Member
Yes...that's it. Never having seen this before, I was hesitant to put pliers onto the head of the tube to try to unscrew it. Discretion is the better part of valor...Northman49 wrote: ↑Wed Jan 13, 2021 1:47 am Here is the F/A tube from a 335.
Al Ciuffetelli
ICCC#1977
ICCC#1977
"Discretion is the better part of valor..."
You should be able to trouble shoot any issues without taking it apart.
- alciuffetelli
- Member
not in this case...the sluggish fuel pick up was remedied by stretching the spring on the metering rod. But I tread gingerly in areas I'm unsure about, thus the benefits of discretion. There are breathing problems that remain, but as always, one thing at a time. Currently thinking I need a new burner cap and screen...but I'm really impressed with how bright this little 335 is when it runs right. Still wish it were a 202...
Al Ciuffetelli
ICCC#1977
ICCC#1977
- alciuffetelli
- Member
Thanks, Bill...that's the kind of information I can use. One of the first and lasting lessons of Fettle 101 is that brass is soft and can break! This part of my problem is fixed...now to find a new burner cap and screen!
Al Ciuffetelli
ICCC#1977
ICCC#1977
