Project 500A
Project 500A
Decided to do another project today. This one I'll call Project 500A!
Started with a fairly decent 500A dated June of 1956:
Removed the four nuts that hold the grate to the burner plate:
Check the hole location where the "Light/Burn" lever comes through the frame rest and then remove the generator and valve assembly:
After removing the two screws that hold the burner plate to the fount, turn the plate over and remove the two screws holding the U-tube burner casting to the plate:
Next, remove the burner rings and air baffle from the U-tube burner casting:
Here's how the top of the fount looks without the burner assembly:
Next, remove the frame rest. The loop on the lever may need to be squeezed slightly to get it through the hole:
To remove the fuel pick-up assembly, one can use a wrench but it's easy to put the brass block in a bench vise and just turn the fount to loosen the valve. Just be sure to twist with even pressure on both sides of the fount so you don't "torque" it to one side:
This is what the valve assembly looks like once it's removed from the fount:
Here is the diasassembled stove:
The fount sans parts and before cleaning:
Time to start cleaning:
Starting with the burner rings, these are pretty easy to clean:
Just use a wire brush:
After the wire brush:
The generator and valve asembly can be cleaned with compressed air and steel wool. Forgot a close-up "after" picture of the generator:
Note above that the generator's needle assembly does not remvoe like a lantern generator. It is threaded into the valve.
Here's a picture of the fuel & air pick-up tube:
The block & needle assembly in the fuel & air tube works the same as when you open a lantern valve 1/4 turn to light it. The Burn/Light lever regulates the fuel when the stove is cold.
Next you see the torch burning out the old fuel cap gasket. For some reason when I first read this in Frank's lantern rebuild tutorials, I felt very intimidated. I bought a lot of one-piece caps instead of doing the torch thing. After doing one, it is pretty simple!
Here is the old cap gasket after it has become a burnt offering:
Here is my preffered tool to remove the burned out old gasket material:
Yes, a Swiss Army knife. Halfway done:
A new cap gasket and one installed on the cap insert:
Now, here's a shameless plug for Don Burchell's check valve removal tool:
Above, the airstem has been removed from the check valve (CV) and the skinny part of Don's removal tool is threaded into the CV. The larger shaft is slid down over the skinny part. The larger shaft has two prongs that go into the slots on the CV. The larger shaft is then tightened down with a nut on the skinney shaft.
The larger shaft has a place to use a wrench to loosen the CV, as can be seen in the next illustration:
Two more pictures of the business end of Don's removal tool:
The CV was stuck. A little Carb-out and compressed air made it work as good as new!
Next, you see the fuel & air assembly cleaned and ready to go back into the fount. But I put some Permatex on the threads before re-installing. The "Pros" have a difference of opinion on this subject. Some us it and some do not.
Here you see the F & A assembly in the cleaned & waxed fount:
The cleaning of the burner parts came out okay, but I wasn't totally happy with the rust removal product I used. So, all of the burner parts were painted with VHT brand high-heat paint. Be sure to follow the curing instructions on the VHT. It will work very well!
Here are all of the parts ready to be reassembled:
Here's a tip to save you some frustration; make sure the nut that connects to the generator is outside of the frame rest BEFORE you put the burner assembly back on the stove! See photo to see what I mean:
Pictures of Project 500A after her reassembly:
Now after all of this, does she work?
Well:
Yeah, hard to see in the light! So here's a few in the dark:
This next photo, the 500A in open full throttle:
Since this was only the second time I had used the VHT, I was wondering how the paint would hold up. I'd say not too bad:
Added 3/15/11: Exploded Stove Diagram:
Including the time it took for the VHT to cure, this was about a four hour project.
Thank you for looking!
kcdarnell58
Project 500A
Post by kcdarnell58 »
Fantastic Murff. FOUR hours, man do you do good work fast. -Kevin-
Jim_l
Project 500A
Post by Jim_l »
Now that's a clean looking stove. Say Murff, do you know when they used green knobs on the 500As? I have a 10/59 but it has a black knob.
I did a four hour project today too but it wasn't Coleman related.
Had to clean out the garage so the wife can get her car in for the winter.
mikewells
Project 500A
Post by mikewells »
Murff, Outstanding, I love this stuff.
Mike Wells
E Bay user name whitegas5152
ICCC # 1038
Jim_l
Project 500A
Post by Jim_l »
Jim, I think that was Joe Pagan. They were 501 and 502s if I remember right.
Project 500A
Yes, Jim! It was Joe Pagan!
Speaking of that, did anyone happen to save the photos of those stoves?
Brent
Project 500A
Post by Brent »
Nice job, Murff! I think Joe's stoves are on Terry's site. Now I have to go look at my 500 and see if I got a greenie. Brent
Do you have an 8/57 lurking in your collection? ICCC Member #731 Ex-Official ICCC person.
Brent
Project 500A
When they get warped out of shape, it's like try to get toothpaste back in the tube to straighten one.
However, if you find a way to do it, let us know!
Wish Coleman would have left the "scalloped" grate on the 500A like was on the 500!
adelcoro
Project 500A
Post by adelcoro »
Good work and fast!! Like a pro!
Yes i like putting some sealer on threads also.......good idea!
All this just gave a new idea..........STOVES!!!!!
ICCC 957
Scouterjan
Project 500A
Post by Scouterjan »
Great Tim, I have 2 here ready to go and part way through my AGM single burner stove. That green knob is cool
Project 500A
Thanks everyone!
I appreciate your kind words. I will move this topic to the How-To Forum in a few days!
Project 500A
Thanks, Bob!
Scouterjan
Project 500A
great Murff, just one thing to add, do not overtighten the cover over the burner rings. It squishes them down and they don't burn as bright, this goes for al;l the stoves with these burner rings
Nevada_Ed
Project 500A
Post by Nevada_Ed »
That top plate that covers the burner rings has a crescent shaped dimple, something to do with flow I am thinking, but I have seen them placed both away from the valve and towards the valve, which is correct?
Project 500A
Ed!
This thread is locked!
I just looked at four stoves here on my shelf. Crescent goes toward valve on all four
