Recovering your avatar
Contact list, Links, ICCC Website.
CaptainFantastic
Title: Coleman Helvetica (CH)
Post by CaptainFantastic »
The forum removed its temporary web domain name (URL) on 19 Dec 2020. As a result you may have 'lost' your avatar after you refresh your browser or log in from somewhere new. You can re-upload it, but to save you the time here is a quick fix.
Go into User Control Panel > Profile > Edit Avatar and you get the screen below.
Edit the avatar "Link off-site" value by replacing the old URL
Code: Select all
http://timothym11.sg-host.com
with the correct URL of
Code: Select all
https://colemancollectorsforum.com
Then hit Submit to save it.
It is real important to use https (with the extra s on there), and ONLY REPLACE up to and including the '.com'. You should keep all the address from the /images... onwards.
